i always look at it like could get pulled into the braking device like they were open farm machinery of gears that will pull you in and chew you up/hands at least. Always visualized such things as greedy, hungry monsters looking for that opportunity, and give that bear a wider path of respect, never poke that beast with stick.
Also, not to be inline with the primary load line in case of rocket launcher type reaction at breech end of the power axis created. Close to braking, can put you in the wrong neighborhood from that perspective...but even spaced from brake want to be offset to the side of this line 90degrees as possible to avoid braking becoming breaking we would say, want to brake load, not break self !
Spaced away gives the clearer view stated, also tried to pre-plot options of if it got fugly would take additional friction on next tree etc. Sometimes started with that extra friction anyway looking to immediately relieve if went as expected; kinda over-prepped reverse strategy of remove not add frictions as plan.
The only times found close to brake useful if plan to lockoff brake or else if kinda have to shove rope into friction brake when still on hinge or rubbing something and wanted brake in chain for impact but frictions were presently over bearing, but at any point body ready/waiting to fall back hard w/body lean away from braking; and if it got fugly where were those next frictions coming from type plotting.
Old drawing (now) bottom left shows personal sentiment about being close to braking (system) as like open farm machinery; where "YOU risk drawing back just a bloody stub!!" (w/o the British accent type bloody meaning, mate).
i draw actual turns now, these were faked, like coil a bunch of many same pieces to look as continuous ribbon.
The black shows off colors, but also hides errant shadows. If was lighter background could see all have shadow glows even around, just don't show unless cross over nonBlack of other item, therefore black background hides all other (errant) shadows for depth, only showing the shadows from crossing over an element more properly.
Years ago some wanted to have chipper painting contest.
i thought all should be as monsters to this imagery:
A chained slave dragged behind truck on road;
only fed gruel of dry wood as it raged.
Starving for fresh blood and meat and seems here maybe comes such a treat wrapped nicely in leather boot.
That is no challenge after gobbling 20' long 16" diameter solid azz oak w/o revving up.
Got any ketchup with that?
Please view all these perils as hungry monsters greedy to take you...to no place good.
