It's innovative for someone who may only need to get up in a tree a handful of times a year, without laying out big money, and using lightweight gear. The redundancies are great for someone who isn't in the regular habit, just in case.He doesn’t use devices, other than carabiners, or an extra lanyard. It’s a safe enough system for beginners that only need to ascend to 20-30 feet.
With so much length in the hitch, it does seem like it could get tight and out of order if one was really climbing around on it.
That's 30".@kany22 what length is that 8mm armor prus hitch cord?
Thank you for your insight. So far it seems to work well for me but there're still many things to try and learn obviously. I hope this hitch will be tested more widely and taught as the go-to hitch for SRT someday.Glad it’s working for you, slightly cheaper option to get into SRT.
Looks like the DMM ring might be too small, the top and bottom sections of cord are too close to each other, not allowing the twist to touch the rope. This causes a V rather than a U shape of the top and bottom pairs of cord sections which adds more unneeded friction. The shackle and pulley probably helps, but I find a pulley isn’t usually needed as it helps very little with the tending. You could try switching the ring and shackle to see if it improves things.
I thought someone had posted up a picture of using the Sticht in MRS with the rope attached to a tending ring, maybe deleted ? A similar method was used with fixed side pulleys back in the day. What was shown would work but the hitch is being tightened at the same time working against you. The front ring is the best place to attach a tender with the carabiner being the second.Did you choose the black figure 8 on purpose on the back U twist rather than the brass pipe for some reasons?View attachment 80086I thought someone had posted up a picture of using the Sticht in MRS with the rope attached to a tending ring, maybe deleted ? A similar method was used with fixed side pulleys back in the day. What was shown would work but the hitch is being tightened at the same time working against you. The front ring is the best place to attach a tender with the carabiner being the second.
I'd try putting a dogbone between the twist and rope and finish off with stopper knots. If that makes sense.I wonder if there is a way to effectively use the dogbone from the hitch hiker device with the sticht and force a bend in the rope, or maybe a clamping effect
I see you like putting the twist inside the ring, I usually put the first crossing on top. The stopper being able to be wiggled while loaded shows that it doesn’t see much tension, making it possible to maybe only use one overhand. No, I mean I got rid of the twist altogether. The back ring is placed between bights and pinched with legs coming from the eye. The legs are then twisted before the stopper knot.I see you like putting the twist inside the ring, I usually put the first crossing on top. The stopper being able to be wiggled while loaded shows that it doesn’t see much tension, making it possible to maybe only use one overhand.
Replace the back ring for a figure 8 for adding friction and you can eliminate the break bar carabiner, which just about everyone says you’ll die if used. Commercially made break bars by CMI and one by me.
It might. I haven't noticed it, but I'm a fairly light climber, so it'd be great if someone here could try it and report back. (Low and slow, of course!)Thanks, I see what you mean, it might start binding with prolonged use, the twist, or a knot prevents the wraps from tightening up.
Forgot to be mention last post your use of the spacer to protect the eyes from wear, much better than the Petzl plastic sheave I tried in the past.
The fear of brake bars are not based on current gear, but unrated, probably weaker carabiners in the past. I don’t use them as I couldn’t get them to generate as much friction as I wanted.
Also tested the back ring compared to large and small bushings for the same use, the smaller ones seemed the best for less friction when tending. Otherwise about the same, except ring is hard to position directly on the rope.
Putting two of the lower sections of the Sticht in series made releasing even easier, to the point there is a slight delay after compressing the wraps before moving. Picture below, iPhone got stubborn after last update, will only put picture at top, can’t write anything above, even in edit.
