macrocarpa
- Midwest
Slow season playing....made a video review of the Makita top handled saws 18V & 36V if anyone is interested in these less expensive battery powered options.
Its a Makita part.Great review, i just got the XCUO6 for a light pruning saw about a week ago. Already had some Makita batteries which made the decision easier. Seems like a great little saw but you definitely need to get used to babying it a bit so it doesn't stop cutting. Is the sprocket a Stihl picco one as well? Be an interesting mod.
Makes for a nice little pruning saw but does have limitations.Thanks for posting this!
New tree guy and member here...
I saw some of your other posts and they are what inspired me to grab one of the 18v saws and do the 1/4" mod. Looking forward to putting them to work!
Stihl worked on the 18v but not the 36V.where'd you order 1/4 pitch sprocket and bar for them?
I've got the Makita rear handle from the first video you posted. It comes with 4 batteries. Groundie likes it.This guy does some very good testing:
I ran into this same problem with my setup. Double checked that everything was the correct parts, it was, so I took an old chainsaw file and elongated the tensioner hole. It only takes a little bit and it worked great. Less than an 1/8" if I'm remembering correctlyI copied your shopping list (thank you!) and the new sprocket finally arrived. Unfortunately I can't get the set up to swap on the 18v....seems to be too tight of chain. Any words of advice having done the mods?
Sounds like an easy fix. I wonder why the same bar and chain are not fitting in some cases? When you extended the tensioner hole does the Oiler still lineup OK? How has the saw been working out for you?I ran into this same problem with my setup. Double checked that everything was the correct parts, it was, so I took an old chainsaw file and elongated the tensioner hole. It only takes a little bit and it worked great. Less than an 1/8" if I'm remembering correctly
Its been working well, but due to job scopes not getting much use on the job. Its super handy around the shop though when needing to make one quick cut in something.Sounds like an easy fix. I wonder why the same bar and chain are not fitting in some cases? When you extended the tensioner hole does the Oiler still lineup OK? How has the saw been working out for you?
Thanks for posting!
