- Retired in Minneapolis
I think that you're going to have a problem using a reel to wind up the throwline. You're likely to setup the throwline for bird-nesting. Google it in relationship to winches. If the underlying wraps on a winch spool are done without tension they are loose. Then, you overlay wraps under tension or a load and the wraps cinch down and tuck under each other. When its time to unspool the cable is bound up or birdnested. Time to get out fids, screwdrivers and tire irons. Hand over hand flaking into a bucket will work better.
What is the source of the plated ring you're using? I wouldn't like a ring in that application with a raised weld even if its rated for life support. There are plenty of forged aluminum rings available with labeled specs lasered into them
