The ring Reed and I use is one of the smaller, maybe the smallest ring dmm makes. Put your lanyard through the ring and slide the ring down and over the top wraps of the Mohican so that when your not using the ring for choke it will sit in the space above the bottom wrap of the hitch. If you use a 4over 1 then the ring sits below the 4 and above the bottom 1.This is what I did...
