Acerxharlowii
- Greensboro
I feel that if you pull on the spine first and then twerk the beak like you’re supposed to the flap doesn’t even matterDoes it make enough of a difference with, versus without?
What didn't you like about Scarpas? I have narrow feet though. They are my go to...But spent a shitload getting here.....will not even go into detail. Took loads of losses. Climbing pants are next....took a hit on scarpas the other day....back to clip n steps.....lol
Great boots but too narrow for me. I have a wide forefoot.What didn't you like about Scarpas? I have narrow feet though. They are my go to...
Sent from my SM-N950U using Tapatalk
Lolol.....you are way worse than I.
Little update on the Marlow Vega. After milking the wholly bejeezus out of this stuff it has finally settled in and stiffened up. Whats left is an absolutely wonderful climbing line. No bounce. Super responsive. Great hand and knotability. Amazing with the Runner, Wrench, HH2, HC, and slack effortlessly falls through the CT footie and the MiniMax. Just be aware when ordering that you are gonna give up a few feet of rope to milking. If you want a 150-200 hank I suggest ordering 10 ft extra.
What holds that thing on?The 4SRT beak is made out of metal and feels great, but it is grossly overpriced.
slick pin holds it in place.What holds that thing on?
Is it just the slick pin or does in snap onto one side and stays in place or is another component that you have to remove to get your rope in?
There aren't any good pics online or instructions and I can't wrap my head around it.
Awesome!hope this is enough pictures for you try to post a video but would not let me. I like it a lot makes big difference to me just pop the slic pin out one tooth and side it over and u can get rope on then slide it back and lock slic pin. If you’re handy you could probably make one but by the time you get it to fit as good as this one you could’ve just bought it even thought they are ridiculously overpriced I’m waiting for someone to make a tender tab that bends and pulls from middle of the runner so it go’s up the rope Evenly not rubbing on one side of the runner
Dang that thing is pretty!Got a package in the mail today
Still all the anodized finish on the friction plate, I’d guess used Runners don’t get more minty than that.
Thanks @dsptech !
For RR tending, I imagine someone making a plastic quickie for use with a slic pin, lighter than the cast or milled version but sturdy enough to provide a more balanced tending function.hope this is enough pictures for you try to post a video but would not let me. I like it a lot makes big difference to me just pop the slic pin out one tooth and side it over and u can get rope on then slide it back and lock slic pin. If you’re handy you could probably make one but by the time you get it to fit as good as this one you could’ve just bought it even thought they are ridiculously overpriced I’m waiting for someone to make a tender tab that bends and pulls from middle of the runner so it go’s up the rope Evenly not rubbing on one side of the runner
And they need to make the pin longer I tried to make my own but the pin is to short now can’t have both teeth engaged the older ones I think the pins were little longer cuz I’ve seen pic with 2 of the Tending plates one on each side and a piece of string across but mine I can’t fit two plates on it?For RR tending, I imagine someone making a plastic quickie for use with a slic pin, lighter than the cast or milled version but sturdy enough to provide a more balanced tending function.
X2 on Metolius, Speedster and Dirtbag II for my climbing lines.I thought my buying days were over. But that never happens. My latest gear fetish is fucking storage. I am addicted to how I carry my so expensive gear. Obsessed. Metolius is my new love. Tried it years ago and said hell no. Wanted simple. What an idiot.
