Bump for an older thread and a fresh attempt. 3/8" Tenex and Tenex-Tec
Following the current version of Samson's Eye and Eye Tail Splice that Brocky posted above.
Attempt 1: Nice uniform thickness along middle, just 5" short of objective
Attempt 2: Correct length but cut tails too short in final step so ended up with a thin spot in middle.
Attempt 3: Too long (just used what rope I had left. Did a better job on the taper overlap but still could improve.
Attempt 4: Hit objective length right on and good taper crossover in middle. I think I need to plan for longer E2E becuase the final corage seems to be a lot thicker than the 10mm.
Left to right = 1-4
Top to bottom = 1-4
A few questions about the final taper crossover. I mark where the core emerges then pull out core to expose an addtional 3.5" then mark. Is this mark where you want to cut/taper? Is the taper/angled cut centered on the cut line? All on the tail side of the cut line?
Just before it goes south...
Here, I cut off the inner core section 3.5" from where it emerges from core. You may be able to see my mark where it emerges ~1.5" from end
The mark is the 3.5" in from where it emerges (Mark X). I tried not to cut/taper anything towards middle of line. Would say this gave the least lumpy middle but still room for improvement.
