I've become obsessed with rigging rings, are they not the best thing since sliced bread?
eyehearttrees
Not a new Member
Tampa-Area
Any recommendations on brands besides 'X Rigging Rings'? These guys, and the 'antal' branded ones, seem the cheapest https://www.atlanticriggingsupply.com/an28lowfrri.html (I'd pay X-Rigging-Rings' prices before buying another pulley/block though I can say that, my 4"-with-swivel gets used for mechanical advantage setups now, nothing else..)
I wish I never bought a single O-ring, they are such sharp bends for the ropes hell I'll take my $1, "1/2" Metal Rope Thimble" that's tied-into a figure-8-bight at the end of a line, over an O-ring, *any day*!! Their bend radius (like a smaller Rigging Ring's) is about double that of a standard o-ring, that is huge when it's such a small diameter to begin with....the O-rings are sub-optimal for both the rope that's knotted-to it and holding it in-place, and for the rope that's run-through it, both ropes get far better bend radiuses with thimbles or (especially) Rigging Rings, in fact I bet that the strength-loss-to-knotting is very very minimal when the rope does a wrap-around of a thimble or rigging-ring....I'm going to have to check Mumford's videos to see if he's done experiments on this, on how much strength-loss to a knot is eliminated when the rope is first wrapped-around a device like a thimble or rigging-ring, bet it's a lot and that the rope keeps most of its strength! Hmmm, if that does turn out to be the case, I'd probably just get more of the $1 steel 1/2" thimbles and do knots-with-bights* except for a pair of heavier duty slings with real Rigging Rings, probably the Antal ones it's just hard to tell if their 28mm ID ring will properly hold a 1/2" line, their damn diagram only shows total-width not slot-width....would LOVE it if someone had a (fairly-priced) source for something like ARS uses on these:
Those ^ would be awesome if priced well (I think an anchor rope that's holding this type of anchor-ring, compared to an o-ring, is *substantially* stronger because again the bend-radius is just so damn steep on o-rings in fact my o-rings are thinner than my climb rope!)
(*I use the figure-8-with-bight, with a 1/2" metal thimble inserted, on my main climb line 11.7mm blue moon, or I did until I stole the thimble for use on a rigging anchor I was making because, well, I'm not heavy enough to even need any anchoring-help on basal anchors, my rope still looks new there in fact there wasn't even an indent after around 6mo of that thimble being there! To be clear I mean these https://www.e-rigging.com/half-inch...9O-AbzQ8YX91mC2yajRLpFQmt7auOdSRoC8isQAvD_BwE they are god-sends, totally superior to O-rings for almost any use you could name and one of the few items that's priced based on costs not inflated based on new-ness!)
Cheaper rings might not have as durable anodizing, a true id radius, and the od groove might not be as deep.
The 28x20 Antal has a slightly less than 3/4” groove.
Harkens have a flat spot inside and the Ronstan ones have an Oval id cross section.
I think Freeworkers in Germany sell the art rings separately.
Xrings are the legitisst for tree riggers. The repeats of heavy doses moving fast create heat through friction and no ring dissipates heat like x rings. Scientifically I've put very large loads into the x, and other rings and they stay coolest under heavy pressure.
Anyone looking for additional information on x rings and the story and evolution of them in the arb industry...I would consider checking out David Drivers pod csst on Educated Climber. It is a fantastic story and @Muggs does a terrific job with all of them.
Enjoy
Yeah these off-branded ones aren't taking 3/4" (my understanding is that, if you're trying to fit 3/4" rope, you can't even use just 3/4" slot you need like 10% wider to account for flattening otherwise your rope's edges will be pressing-into the edges of the thing, hopefully they're smoothed/machined well!)
Thanks a ton for the recommendation am going to go check them out, am about to make a thread for help on choosing a heavy-duty rigging setup because I only have medium-duty now (so for my 1/2" lines these off-brand ones work great!)
Re the Harkens, that's good to know thanks! Re Ronstan, you mean oval-ID in a good way right? (can't tell which orientation you mean 'cross section' relative to in this context, still in coffee mode :P )
Re the andonizing, I can't say I'm seeing much issue there in fact I'm uncertain there's much significance one way or the other insofar as how slick the rings themselves are (within a certain range of smoothness, obviously they could be too rough!), I mean the additional friction going from the slickest andonization to just rope-worn steel or aluminum, it can't be that big a % friction-gained and you could argue that additional friction is a good thing (to a point, but that point is well-below any friction from less-than-glossy rings!)
What do you use for your setup / what do you do with it, if you don't mind posting it? I'm unable to rig anything large so I can't even do a proper blocking-down of a tree right now because I'm trying to limit loading to around 1k lbs (1/2" line running through rings and either held or wrapped around the trunk at the bottom), gonna go make that thread to get an idea what I need for properly blocking-down a tree!
there's also the bend right ring, and fiori's ring, both are custom for tree work, haven't used either, but they look beastly
WOW these are totally my favorite, wish they had a single result on Google Shop though, what a great idea https://www.bendrightrings.com/our-rings
Thanks for posting that, honestly I feel the 'evolution' of these was more of an "aha!" moment and less a process (like the Wrench) but had forgotten all about that podcast thanks for the reminder :D
Upon further inspection of their graph, they're showing a triple-ring setup wherein the middle ring is NOT higher-than the outer rings, which would obviously defeat the purpose of using 3 rings lol, kinda disingenuous (which is silly because their design is top notch they don't need to argue it lol, it's obviously superior for SINGLE ring applications although I'll take two rings (of any type) over these Bend Rights any day, or 3 rings of any type over 2 bend-rights...they're certainly the best profile of rigging-ring, but using multiple rings the *right way*, ie not how they're picturing it, allows you to create a massive bend-radius for instance the 3-ringed X-rigging-rings anchor let's you set 6" to 1'+ bend-radius depending on the tree, as-does something like my current setup where I've got a prusik on my 5/8" line that I adjust to create a 'high point' for the rope, just a lil bit above the height of the ends of my anchor-rope, to smooth the bend-radius and eliminate those sharp-bends shown in Bend Right's product-diagrams)
edited-in: I especially love their thinner inner-diameter to help the rigging-line keep its shape / prevent flattening, am going to try and actually find prices for these but am trying to put together a heavy-duty rigging system right now and the top anchor was to be 2 or 3 rigging-rings, am now dead-set on it being 2 of these Bend Right rings (can't stand how common these 1-ringed anchors are, when you're basically basket-hitching because you have 2 rings you're about doubling your MBS of the anchor, why the heck would you get 1 ring and cut the strength of the product in half? Double-ringed anchors are so simple to use, just wrap it around the trunk extra times if it's too long, I see all these loopie & whoopie options and can't imagine how anything could be easier than wrapping & tucking a double-ringed anchor rope...mine's 8' long / 5/8" and can go anywhere :) )
Didn't realize Google would fail finding these
It's the bend-right's that aren't available, even their website's store looks as-if they're just selling-off the rest of their stock....sucks because they totally had the best design I've seen yet (the tightness of the hole to prevent flattening is brilliant), hope they're not going-under although it appears that way (maybe they should've sold $200+ blocks..)
DUDE thanks for the video he showed a trick that makes a HUGE deal for me because I've 'got the issue' that I want to buy cheap rings but don't know how to splice (my attempt to splice my Blue Moon ended as a 3hr nightmare lol), he just took a rope that had an eye-splice on the end and choked/hitched the ring with it, thing bit perfectly that is totally how I'm going to do this (just ordering a 3/4 or even 1" thick section of tenex with spliced eyes on either end of a ~7' or 10' section, I like to overshoot size since I can just do extra wraps if it's too large I never understood why there'd be appeal to canopy anchors that are 3' or 5' they're so limited!)
Wraps are always going to depend on the dbh... If you want strong and adjustable then consider the ultra sling. Very versatile and you can both choke and basket hitch configurations.
I hear your cheap but consider the dmm thimbles. I make my own snake anchors with them.
But I always wanted to try the snake anchor and I always wanted ART's aluminum ring thimble.... awesome to see it sold separately.
WOW I didn't realize they were that wide, **STRONGLY** URGE people to give these a shot for light-->medium duty terminations when you don't want to go all-in on rigging-rings:
I paid $1 apiece for mine (got 3) when placing my 1st-ever order, just used the calipers and they're 15.5mm wide (compared to 9.5mm wide for the standard O-Rings, that's more than a 50% surface-area increase!!)
Honestly I'm proud of myself for having thought to grab these (was being told not to at the time, that this wasn't a proper use-case for them, although subsequent experience as well as seeing other retailers offer ropes setup with them has made me believe otherwise!)
Have these on either end of a 5/8" thick, ~8' long rope that I just wrap-up for my anchoring, obviously they're not as heavy-duty as rigging-rings BUT let's remember that the weak point in these setups isn't the metal it's the rope, these rings are unlikely to go before the rope does BUT if they did they would simply bend...totally worth a buck :D
View attachment 62596View attachment 62597
Just make sure those thimbles are very smooth. Keep inspecting then and file/sand down and rough or sharp edges.
I heard of guys using them back in the days along with stories of them cutting ropes.
<iframe width="560" height="315" src="
" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
scope out the ground around the 2:40 segment!
What brand of rings are you measuring, the rings I have are between 12mm and 14mm?
Those thimbles are boss I forgot about them, I use the ~$1, 1/2" rope-thimbles to great success, they're 15.5mm wide compared to 9.5mm for standard O-Rings, I have these on either end of an 8' long, 5/8" bull rope as my medium-duty canopy anchor right now and intended to get more to start replacing my o-rings but will check DMM's, I feel like such thimbles are fine for any rigging up to 'medium', although I need a stronger setup for blocking/shock-loading and am 99% set on the triple-headed X Rigging Rings 3/4" tenex sling 5' long, it says "for crotches only" but if I added a 1/2" tenex prusik to it I could choke it around a spar / trunk and it would be fine (I have to imagine!!)
I've also got a line on a lightly-used Notch "Safebloc" the 3-holed "rigging ring plate", although I'd initially dismissed it out-of-hand because I disagree with using that much friction that early on the line, I'm now thinking the thing could be an awesome basal anchor IE a mini-portawrap insofar as, if the friction is sufficient, it's almost like a 1-3 wrap portawrap but it'd be part of the anchor rope itself, love the idea just wish I knew how much friction it provided need to check youtubes (hate the idea of using a rope in a 1-piece termination like the Safebloc when it's possible to use both ends of the anchoring rope, basket-hitching doubles your strength seems absurd not to use this when-possible!)
