The Safeguard just came out, and definitely would be better for tree climbing.
The Lifeguard locks up reliably, but because of the spring , it releases the rope as soon as any weight is taken off of it.
Both put a bend in the rope, so you can't use a foot ascender.
It would seem that the non-spring version is now known as the Safeguard and it's only available in black.
I got my Safeguard and did some low and slow practice maneuvers using a throw hook/lanyard.
1st impression was that the moving parts rattle around a bit when unweighted. When lightly weighted, pushing down inadvertently or intentionally on the cam releases the climbing line, allowing it to slide freely in a bidirectional way. This helps when tending, but raises concerns as far as it being able to slip on the rope when inadvertently or intentionally unweighted. When properly engaged and weighted, it performs very well, as expected. I really like the compactness and the range and the feel of the metal lever. The shorter (90 degree) distance on the arm's reach, makes it easier to dial into the sweet spot. While I have not yet used this as a primary rappelling device, it seems to perform much like the GriGri and it can be a bit jerky when it initially releases the climbing line, making it all the more important to retain control with your breaking hand. The orientation of the lever makes it align in a more user friendly way than the GriGri, as well. It seemed to work well on my 1/2" Vortex and 7/16" HTP Static, even though the 1/2" slightly exceeds the recommended rope size. The device also tends much like the GriGri, and performs well in a 3:1 Rad configuration.
The Safeguard will most likely replace my GriGri2, as a multicender on my DMM Captain lanyard, for the main reason that it's all metal, slightly lighter and smaller than the GriGri, and it seems to be as good as the Cinch, while working effectively on a 8.9mm to 11mm size range of climbing lines.
The low cost in comparison to similar devices is compelling, but the device may not be as ruggedly built it and may tend to wear out sooner. I feel confident using this as a lanyard adjuster, in both a SRS and MRS, but I would not feel comfortable using this device solely as a primary multicending device, like the HH, RR, RW, or Uni. If asked whether an existing GriGri or Cinch owner might be compelled to buy the Safeguard as a replacement, probably not, unless it's time to upgrade a similar worn out device, in which case, the Safeguard is a strong contender, IMHO.
Very nice review! Sounds like they need to make another model with a cam spring that keeps it engaging the rope, the opposite of the Lifeguard, which releases when just about any weight is taken off of it. It might help to keep it engaged if there was some weight below it, to rotate the device. Or set it by hand each time you want to stop.
Anyone have any issues with the Bolt being too long and causing the hook to bind up? I experienced this twice today in an oak with some branches that were right one the limits for the hook. Still, twice and I started looking at it. Might have to take the grinder to it.
Can you turn the shackle around, with the protruding end of the bolt aimed out inside of to the inside?
Yes.. it truly is small.. i think Camp Saftey has a couple similar devices in size.. but very expensive & full of features we wouldnt typically want. Good features for falling, but not necessarily working..That safeguard is tiny !! holy crap. @TREEfool you're going to like it
A warm welcome to new forum member @hanis943! I think you are going to like it here! Don't be shy about posting, there are a lot of really nice folks here. I hope to read something from you when you feel like sharing your experiences.
Thanks for signing up to be a member!
Tim
Why not just use a swivel biner? That way there's less clutter when your not using it... Also if you haven't used that attachment before, give it a try, it's definitely different than a rope bridgeGot a chance to test out my Captains Hook today. Very cool tool, but will most definitely need some practice. I run a DMM small axis swivel on my rope bridge, but found my bridge to be too long for my rads system on my hook to be as efficient and effective as possible. I am using a gri gri with hand ascender/revolver and footie. I have to 2018 version of the SRT Sequoia and was thinking an open ring on the ventral attachment would make a nice option for the hook as well as possibly ascent. Just wondering if anyone has tried this and any thoughts or opinions would be greatly appreciated. Thanks
Never really thought about it that way, but it definitely aligns with what I found worked best for me as wellAfter many climbs using the Captain Hook i’ve come to the conclusion that a straight-through path is best for whatever progress capture you’re using for the hook. BDB, Rope Runner or Akimbo seem too much money for the use but they work so well on the hook. To go simple and cheap just use a hitch and a pulley tender. You can take load off the hitch with a hand on the tail below (or above) the hitch for shorter downward movements, THRWT, the human rope wrench technique ;-) With a straight path through device or hitch you don’t need a RADS and bridge length ceases to be an issue.
