Yes. Keep in mind I'm not a mechanic. So as it was explained to me the airbag is a system not individual airbags. As the chassis shifts on the suspension they transfer air from bag to bag to compensate, or drain and refill. Having the truck on a bag instead of metal on metal allows the airbag system to try to compensate for what the boom is doing to the suspension of the truck. It makes it much less stable than the steel on steel. I like this feature. I think my chassis with the air drained is even more stable than a truck with a non air suspension system. Plus I drop the bed about 4 to 6" so I lower my outriggers even less. Another good thing is I can back in over things and dump the air and set up where I wouldn't have cleared it before. For instance bottom rail to a fence, landscape features. It's the next best thing to the pivoting outriggers they install. I just couldn't justify the cost on that feature. This jacking and lowering with the airbags is the next best thing.
I love the KW. Wish it was (A) new and (B) not an 18sp. Other than that the AC pumps the cab down to 47f. Who doesn't like that in summer.
That's what I was picturing.
On the setups I've ran the boom was attached to the outriggers and that to the frame, to me the only benefit to using the frame/axles/wheels that way is to prevent sinking, but if your set up tight that's not been a problem, and I figured the unit to be self supporting and not reliant on those other components.
I know what you mean about waiting for the bags to fill, try that when you have a system with 20 bags lol. Most of the trucks I ran hauling heavy had what we called 4 down 4 up or 5 down and 3 up, the up axles were tags on air and then the truck had air, even on those it took forever to fill them. Many of the trucks the air dumped when you turned the key of, so you didn't turn the key of when you were loading or unloading.
I wouldn't set the air to pump with the PTO unless there was a manual override which would be pretty easy to set up, but as Stephan was saying it's one more thing to go wrong and one more thing to bypass if something goes wrong.
This is the kind of trailers I pulled when hauling heavy the last 7yrs I did that.
I know all to well about 18's, 15's and 13's, never really need to split the low side, but the top was always needed when loaded.
