Has anyone done this or have recommendations?
I picked up a 2003 bandit 65aw for $300.00 in pieces , needs a motor , I am going to replace a old Honda 20hp with vanguard 35hp but all the mufflers are on the back of the motor , guess I need a side mount ? Also where can find a wiring diagram for the chipper Thanks for any helpI just did this last month on my '97. The original 25 Kohler (actually 23.5) died. I opted to replace it with a 35 Briggs Vanguard. I had a welder move one slide rail for tensioning the belt forward and cut me a new engine mounting plate for the larger footprint engine. I am VERY happy with the additional power. I upgraded from 68BX to 68BP belts on the existing double sheeve pulleys to handle it.
Your option looks a LOT less expensive. However with the 35 the chipper can keep up with the pace I want to work. Barely ever need to pause the feedwheel to let the disk come back up to speed. Only on 4.5"+ stuff that is more than 8' long.
Also where did you get the exhaust and motorI used the Briggs right hand side exhaust parts.
842263 MANIFOLD
to
842262 MUFFLER
to
841518 PIPE
