Singing Tree Quickie out of stock everywhere.
Wow a 1000 pieces!
That had to suck having to inspect that many.
Were the issues affecting both the stamped and milled versions?
The milled versions are out of stock as well.
Probably due to the cast version issues.
Just my luck.
I was looking to buy a couple of the cast ones this weekend for SRT use with the HH2 I just purchased yesterday.
Finally going to make the switch over to SRT.
Just my luck.
The HH2 and a choked quickie anchor is my #1 set-up for removals.
Just my luck.
You can use mine. PM your address and I'll send it to you. You can sent it back when you get your new one. I'll pay USPS postage to get it to you if you do the same to get it back in a few months.
Thanks for rejecting them Nick and TS!!! Sorry for the issues it causes you.
I second that.
Not so much an issue just have to be patient a little longer.
When the next batch is accepted I'll know they will be safe to use thanks to Nick and TS.
Thanks for backing up my decision on this setup.
Pardon the ignorance. What are the major differences in the milled and cast versions. I use one with an Alpine Butterfly for my top tie. Are these safe to use?
In the past, I asked @bonner1040 if the squared surfaces on the cast version led to decreased break strength, to which the reply was, paraphrased, "no, TS break tested rope without a decrease in strength."
