Finally joined the crane gang..
You might want to check the load rating on the fly jib. I'm not sure about Effer, but a Palfinger crane that size would be limited to 5000 lbs on the jib. Nice looking crane! Now everything can be a "crane job"!
It was really close range, with the jib all in. The crane shuts u down if your trying to lift to much. It started beeping close to 90% once but pulled everthing closer (extensions) and was ok. I'll have to look at the chart again
Thanks iam happy to add it to my arsenal! What crane do u run? Mecanil saw?
