Hello all I have been following along and I was hoping to get some opinions or advice.
I am a very small tree cutting trimming operation. Most of what I do is milling I either pick up logs from other tree companies or pick them up from their clients houses. I am looking for a Mini that can get a variety of things done. Moving logs, moving rounds, bucket dirt work, dozer dirt work, maybe roto-tilling, trenching, maybe stump grinding, and maybe a mower attachment. I was originally going to get a full size skid steer but it was cost prohibitive.
Now that i have decided to go with the MINI. Things I am looking for Maximum lifting weight, lift height over 85" this is pretty high for a Mini Skid Steer (height of the sides on my 6 wheel dump truck), dual hydraulics so I can run a rotating grapple or a 6 way dozer blade, and if I am getting a mini I want to be able to fit through a 36" gate or doorway. Mild considerations are motor power and speed forward and reverse.
I live in Sacramento, CA area the "City of Trees" I have every major brand dealer in town and within 30 mins of my house.
Boxer
950- HD
PROS Lifting capacity of 957lbs, Dual auxiliary hydraulics
CONS wider than 36"
http://www.boxerequipment.com/equipment/boxer-950hd-compact-utility-loader/
700-HDX
PROS has dual hydraulics but lower flow, retracts from 43 down to 34 inches
CONS lifts 693lbs
http://www.boxerequipment.com/wp-content/uploads/2017/02/Boxer_700HDX_Specs.pdf
Toro
DINGO TX 1000 NARROW TRACK
PROS 33.7" wide, lifts 1000lbs, auxilary hydraulic pump flow is 15gpm
CONS 81" lift height, only one aux hydraulic line
https://cdn2.toro.com/en/-/media/Im...ers/Dingos/490-9226_Dingo_Brochure_FINAL.ashx
Ditch Witch
SK1050
PROS lifts 1062 lbs, Dual Flow Aux Hydraulics
CONS 83" lift height, lower flow aux hydraulics, 42" wide
https://www.ditchwitch.com/sites/default/files/SK1050 Brochure_0.pdf
SK1550 (THE BEAST)
PROS lifts 1558 lbs (Highest I could find), Dual Flow Aux Hydraulics, 94.5" lift height (highest I could find), Large 44 HP motor
CONS 46" wide, lower flow aux hydraulics compared to other brands and given motor size (13gpm and 3gpm)
https://www.ditchwitch.com/sites/default/files/CMWC-7965-01-SK1550-SalesSheet_v3.pdf
Bobcat
MT-85
PROS looks beefy well known brand, 35.6" width
CONS 850 lbs lift capacity (lowest of the larger mini skid steers), 25hp motor, 80.9" lift height, only one hydraulic auxiliary output, reverse speed half of forward speed, CAN NOT curl and lift bucket at same time.
http://www.kubota.dk/fileadmin/user_upload/Datablade/Datablad_d902_32.pdf
Vermeer
PROS 1035lb lift capacity, 88" lift height, 36" width, dual auxiliary hydraulics (15.5 and 8.1gpm), 40 hp motor
CONS Newer not yet fully proven or tested
https://www.vermeer.com/documents/1/2030/CTX100_Spec_Sheet_1016.pdf
