True. What I dont understand is the throat of the splice, is it a locking brummel. I'm new to this splicing stuff.
Thanks
In response to your question,
1) measure your burial tail
2) calculate the amount of line for your
3 Brummells
3) measure the circumstances for the X
Rings that you'll be using
4) add the 4 lengths that you will use
for the line through line, roughly
6-8" between the X Rings and
the triple Brummell
5) taper 1/3-1/2 of your burial tail
6) put extreme tension on the X Rings
and the long tail to remove all of the
excess tension from the rig
7) bury the short tapered tail right
after the triple Brummell, and milk
Any slack out
8) whip stitch and if you want apply
heat shrink over whipping, if you
want to
I hope this helps you with how to assemble a Double Ring Rigging Sling.
Best of luck and take your time!
Dave R
