frashdog
- Champlain valley, adirondack coast
Man I'm so glad I did not but a tracked skid steer.
Our Ram Rod 900t is down for the moment due to hydraulic motor failure...not bad it lasted over 10 years. $300 fix.
We rented a ditch witch diesel jobber for a week. Now I considered my self a decent operator...before I drove this beast. This thing just wants to tear lawns apart. It's like I'm actively preventing it as I operate it. Forget about feeding the chipper with it. That pivot maneuver in front of the chipper, I can do so smoothly with our wheeled jobber on lawns does not exist in the realm of tracked machines....not with out ground pro.
I can wheelie tail or nose depending on load with the wheeled unit and pivot on spot. Not happening with the tracks.
The controls are not for running a bmg either...constantly have to switch hands to work.
Now if you are digging...this machine is the money. Got tractive power? We moved some chip piles around in a manner not possible with our wheeled unit. And yes the lifting capacity is a bit more... Hope so on a machine that is almost two feet longer and 800lbs heavier.
If you work on lawns...wheels.
I'm sure there are some master operators out there..After 5 years, I'm clearly not one of them.
