treebing
- Detroit, Mi.
SRT= Single Rope Technique. The climber uses one rope
dSRT= dynamic or Doubled Single Rope Technique (also known as DdRT)
sSRT= static or stationary Single Rope Technique
DRT=Double Rope Technique. The climber uses two rope independently
Currently at the ITCC there is misuse of the term SRT. There is discussion of single line work positioning versus doubled rope positioning. The problem is that tree climbers climb SRT, and have been forever. They use one single rope. The single rope technique that they can use can vary. For example they can use a dynamic single rope technique such as a traditional blakes hitch climbing system where the single rope is folded or doubled.
Or you can have a static SRT system where the line such as a rope wrench system where the line is static and doesn't move.
Currently the term ddrt or (Dynamic or doubled Single Rope Technique) is confusing as it appears to be closer to DRT than SRT. Where does the second D come from in dDRT? dSRT is a specific Single Rope Technique.
static SRT is then referred to simply as SRT which is a broad term that encompasses both techniques.
DRT should be very specifically reserved for a technique used by professional workers at height who for safety reasons climb with two independent lines, one as a backup, one as a mainline. They are always tied in twice. This means they are two mistakes from falling as opposed to one mistake in SRT. For rope access workers, being tied in once is an instant DQ on the certification exam. In the climbing competitions being tied in 0 times is an instant DQ. The same as dropping a carabiner.
Professional workers at height are confused when they see differentiation of SRT and DdRT ( where does the second d come from?) As they just call it all SRT. For all safety purposes one rope is one rope. Two ropes is Two ropes.
