climbingmonkey24
Carpal tunnel level member
- United States
Today I terminated a contract and walked off the job after starting…not a typical experience. Here’s why.
We had a contract, signed and dated, that specified exactly what was gonna be done with the hedges. Nearly an hour after we started, they come out telling me they are unhappy, why isn’t it more straight, and also they want me to go in more. The amount they wanted me to take it in would leave it completely hacked and down to bare stubs. This wasn’t what we agreed to. However, I tried to meet them halfway and go in a little more. Still wasn’t good enough, goal post kept changing.
Regarding the bow, that’s because a section of the arborvitae were younger and therefore not as wide. So I followed the natural contour of the hedge like I’ve done on dozens of others and did my best to blend it in, trying to explain that to get it to a more straight line would mean cutting severely into the wider arborvitae.
Then they said the stihl extension hedge trimmer I was using wasn’t the proper tool, that I should be using a chainsaw to cut the sides until it’s almost bare.
When we initially looked at the job, the client stated they wanted both hedges on either side property to eventually be same height. One was taller, one was shorter. What we talked about and what we wrote in the contract was the taller hedge we would perform a reduction or 1-3 ft, and then the shorter one either a light trim or let it grow depending what the final height of the taller hedge comes out to, with the long-term goal of matching them.
Now they don’t want that, they want to perform a more significant height reduction on the shorter hedge.
I’ll try to accommodate changes and things as much as possible, but the whole nature of the project changed from properly trimming an arborvitae hedge to hacking them back to bare stubs all the way around. That’s just not the kind of pruning we do for obvious reasons.
And then when I pulled up the contract and tried explaining why I was doing what I was and my thought process, they said I was trying to make things more difficult.
They don’t care if it kills the trees, it’s just a tree they say. Okay, but that doesn’t change the fact that it greatly changes the scope of work and how long it’s going to take.
Never has someone suggested to me that I should be using a chainsaw on the sides of their hedge instead of a professional hedge trimmer.
I’ll put up with a lot, but I felt no matter what I did it wasn’t going to be good enough. All I was doing was wasting their time and mine.
Put in a half day’s worth of work, cleaned up my mess, and didn’t charge them for any of it.
