Would just climbing higher and having your climb line in another tree near the trees being removed allow you to take smaller pieces so that in the one example that branch wouldn't have got hung up and then eventually end up right in your face?
Casey there was no good option for tying into another tree.. This was not that big of a tree and certainly could have been pieced out, and there was a large live lead to tie into, but that would have been much harder, as a lot, if not most of the tree would have had to be lowered. Handling that would have been quite difficult on the ground as the terrain was very steep and there was a beautiful dogwood dirctly below the main live top.
Bt taking the pieces long liek that, I was able to clear the hill and the dogwood with the brush, which all ended up out on the lawn, (except the piece that fell back into the tree, which we picked with the skid loader). Had the loader not been there, it would have been troublesome..
If I wanted to be certain to keep that piece in the lay, all I had to do was tie a long sling to it and send it down the speed line as well. If there was a mistake made here, not taking the time to do so was it. I honestly thought it was short enough to clear the adjacent tree and still fall to the lay. So I definitely learned something there. Maybe if I had cut it better and the hinge failed a little earlier, it would have made the lay. In any case I was pretty sure it wasn't long enough to do any serious damage, and I will defintely file all that was learned from that drop in the computer. So I'll call it a learning experience.
One issue was indeed time. I was using all throw away lines and slings for the speedline, and that would have taken a few minutes to find or cut a proper sized sling for. It also took a few minutes to fish out the butt.
