Xman,
How does having the 2nd pulley on the bottom take much weight off of pulley 1? Is it kind of more spreading the weight across the stem? If pulley 2 was higher then pulley one would it transfer more weight off of pulley 1 if for example you had a good sturdy stem above where pulley 1 was? Just trying to piece this all together.
Thanks.
i read you type again. yes, if pulley 2 was up higher, then 1 on a good strong stem down force may be reduced at pulley one. but you also risk the chance of pulley one trying to get pulled toward pulley two.
but I have done this too. depends on the diameters and situation. often on a similar situation, if the limb I have a block out on has the potential to fail at a v crotch or something, i will take the tail of the sling used for the block and after i tie the block on; take that tail over to the other opposite side and tie it off on the opposite of the v crotch. kinda like a temporary cabling job. very simple, but if my words don't make sense, i will draw.
