rfwoodvt
- This side of eternity.
Upgrading our two-way handy-talkies so we're moving these out the door.
They have Part-90 Certificates but no Labels because they were made prior to 2013.
I currently have them up for sale on ebay if you want to go bid on them.
If you want to do a Buy It Now I'd be willing to knock some off the ebay buy it now price. How much will depend on how many you want and which ones. I'd also be willing to combine shipping if possible. Just let me know and we'll handle that transaction here.
Here's the link to my auctions:
http://www.ebay.com/sch/rfwoodvt/m.html?item=252286424303&hash=item3abd7154ef:g:at0AAOSwFNZWv4fP&rt=nc&_trksid=p2047675.l2562
All of them work just fine and the batteries hold a charge. The batts are about 4 years old so I don't know how long they will continue to do so, though. HA3 is missing the SPKR/MIC cover and HA4 has a wonky screen. Doesn't always show the full display but pressing your thumb on the screen will bring it back.
The Pictures below show (from left to right, HA1, HA2,HA3 and HA4)
Main Features
. UHF Dual frequencies & FM Radio
. Dual display and standby modes
. 128 memory channels
. 1 groups scrambler
. Channel name edit available
. Output power VHF 5W/1W
. High/Low power can changeable by top key
. VOX (Level adjustable)
. DTMF encoding and DTMF decoding
. 105 groups D.C.S/50 groups CTCSS
. DCS/CTCSS of RX and TX can be set respectively
. Reverse frequency function
. Busy channel lockout
. Distant alarm
. ANI (Caller ID)
. Multi scan mode (TO/CO/SE)
. Inspection, monitor, stun, kill and emergency alarm
. All calls, group calls and selective calls
. Calling ring and ring overtime auto answer
. Multi silent mode (QT/QTADT/QTXDT)
. Channel steps (5K/6.25K/10K/12.5K/25K)
. Wide/Narrow bandwidth selection (25KHz/12.5KHz)
Features
5/2 tone and 1750Hz burst tone
. Priority scan
¬¬KG-699E Technical Specification
Frequency Range UHF: 400-470MHz
Channel Capacity 128(200)
Channel Spacing 25/12.5KHz
Maximum Deviation±5KHz to 25KHz ±2.5KHz to 12.5KHz
Frequency Stability ±2.0ppm
Operating Voltage 7.4V
Operating Temperature -30℃~+60℃
Battery 1300mAh(Li-ion)
Standby Current 50mA
Antenna Impedance 50Ω
Dimension(without antenna&battery(L×W×H) 105×62×39(mm)
Weight(with antenna&battery) 260g
Transmitter
RF Power Output VHF:5W/1W
Modulation 16KфF3E/11KфF3E
Spurious and Harmonious -36dBm<1GHz -30dBm>1GHz
FM Noise 40dB
Adjacent Channel Power 70dB/60dB
Audio Distortion ≤5﹪
Receiver
Sensitivity(12dB SINAD) 0.25μV
Selectivity 60dB
Intermodulation 60dB
Spurious Response Rejection 65dB/70dB
Audio Power Output500mW
Audio Distortion ≤3﹪(0.5W)
Main Features
. Distant alarm
. ANI (Caller ID)
Features
. Priority scan
Transmitter
FM Noise 40dB
Receiver
Selectivity 60dB
