Tr33Climb3r
- Wisconsin
I know. Just having fun with it.Evo is the way forward for sure.....agree 100%. My post was not thrown at you Casey more a general response.
Buckles are different suppose to be easier to adjust.Nobody has shown me any difference between the old tm and new tm except the lower ds
This is what I thought all along too but when I saw what looked like price tags by all of the parts for the conversion, it had me wondering.They do not sell the lower D's. They only sell the replacement parts for the Evo. no way will there ever be a lower D conversion. Suck it up folks. I still have my TM which is my 3rd, It is two years but will get the Evo eventually.
Word so just order the Evo parts for the "evo" and I'm good. Pretty sure Kevin bought the Evo then ripped off these parts to retrofit his tmlight . So it can be done but isn't endorsed and voids warrantees. Which I assumed but thank you.@Mowerr Below is the response I received from Teufelberger.
"The treeMOTION Standard and treeMOTION EVO are certified in the structure that they were designed, manufactured, and ultimately shipped / received by the consumer.
Any alterations made to the harness set-up/design that deviates from the approved design as submitted to be certified will void the certification of the harness. So for this reason the D-rings on the new EVO cannot be retrofitted onto an older standard version of the treeMOTION saddle. Nor will we provide D-Ring replacements to be used on a standard treeMOTION"
I have a sewn bridge to make my older tree motion have two bridges. I bought two dmm large oval focus shackles and then put the leg and hip webbing through the shackle as well as both the knotted rope bridge and the sewn bridge. I originally did it with Petzl open rings then I found the dmm shackle which are much more compact.Bumping to ask if anyone has switched from the stock 125 cm knotted bridge to either the 180 cm knotted bridge or one of the sewn bridges, and if so, what length? And why?
I only see the ring in the pic. Do u have a pic of your setup with the shackle?I have a sewn bridge to make my older tree motion have two bridges. I bought two dmm large oval focus shackles and then put the leg and hip webbing through the shackle as well as both the knotted rope bridge and the sewn bridge. I originally did it with Petzl open rings then I found the dmm shackle which are much more compact.
It’s much better with the shackles just got them on the other day.I only see the ring in the pic. Do u have a pic of your setup with the shackle?
