If I have a remote rigging point, I'll usually go more open face, I want the hinge to break and have the piece come off about the time its laying out flat, best I can figure, it helps to smooth out the "pendulum" motion of the swing, along with the fact I'll notch it AWAY from the rigging point, so I'm swinging the load into the rigging, as opposed to dropping it into it and increasing the shock load. If I can get away with it I'll use it where I can, in trees that cant be dropped, but dont need to be rigged down in any particular, like multi-stemmed oaks or pines where you can save a bunch of time by not having to set multiple rigging points, or having to move it at all.
If again, its a tree that cant be dropped, but doesnt need to be rigged down either, I'll generally go with narrower notches to try and flat drop BRUSHY pieces, since we're getting specific. Like I chunked down a few big pines this weekend, and I'd go narrow on the tops and flat fall them, and then with the wood, I'd go open face. Reason being, I wasnt using a pull line, and alot of times its tough to get enough momentum to snap the hinge on pieces with a narrow notch. I go wide so the piece will go far enough over center to break the hinge, and I'll give it a little flip of the hand as needed to get the right rotation to get it landing as flat as possible.
That help any?
