TreeFlex Rings Response
All of the components of TreeFlex are tested as part of the EN813 harness standard. I have presented this on TB before. This also involves salt spray testing (salt is a serious corrosive of alloys). It can be found here
http://www.treemettlenexus.com/pdfs/test_report.pdf
The notion that all components of a harness carry a load rating is impracticable, and sometimes impossible (i.e the thread!). Proof testing is a similar issue.
The purpose of the EN testing is to test how all components work together in a likely fall that the product was designed for. The product is then made to the same specification of each component part used. The harness has also been subjected to the fall arrest forces of EN361, but this is by the blue webbing, which bypasses the rings; this is for using the harness in full body mode. If anyone witnesses such a test they will immediately realize, it is so extreme that survival of such a fall without serious permanent injury is doubtful.
Requiring 2 ton strength of components in a harness does not protect a climber any better in a fall; the body will rupture at half that force, regardless of whether the safety system does. If fall arrest forces are possible, some form of energy absorption is essential.
My personal opinions
It is certainly alarming that the ring in question failed. But we need to think about how we routinely operate at work and in competition that can pre-dispose us to these risks:
1. It is something of an accepted culture that climbers routinely swap component parts in their safety system, without accepting the risks. In this case, it appears a ring was installed to a harness that (I don’t think???) had been tested as part of the EN standard for that harness.
As stated, the EN standards test how the component parts work in a worse case scenario, for which the product was designed.
The harness itself is a component part of a wider safety system, for which Europe has stringent standards to ensure the correct equipment is used as intended and tested.
Arboriculture can be something of an anomaly in this respect (see point 2), as many operators routinely use equipment beyond its design parameters.
2. The situation that led to the failure has been entirely overlooked (in this thread at least). I have stated before that certain competition maneuvers appear to me to expose the equipment and climber to fall arrest forces for which work positioning equipment is not designed.
3. The competitions appear to routinely allow or even encourage modified equipment, with no actual knowledge of how the modifications affect the safety system.
This is further compounded by encouraging systems and procedures for which no data is available with regard to the forces involved NB Has anyone ever placed a dynomometer at the anchor point and simulated a leap from a limb for a target and then a sudden arrest (such as if the hitch jams)?
4. The difference in international standards is not reflected in the competition.i.e. equipment may need to be used beyond its design parameters to successfully compete (points 1 & 2). After all, it is an extreme recreational event.
5. Industry is unduly affected by events at competitions, hence this thread; what may be acceptable in competition as an extreme event, is not necessarily acceptable in daily work, but that is never conveyed.
Industry has never shown intention to resolve these issues successfully, and I doubt it ever will. Hence, due to lack of clear industry leadership on these issues, it is down to employers, operators and competitors, to adequately determine the risks of their undertaking and apply suitable controls. As is becoming more commonly evident, failure to do so has serious consequences.
I’m glad the competitor in question appears well and unscathed, and sympathise – I have run the same risks and gotten away with them; I undertake work differently now.
Please direct comments and opinions on this post to
paolo@treemettlenexus.com.
Best regards
P.
