Hey Taylor, I like the looks of the Celanyard and the clever design behind it. With the addition of the new Ocean Vectran line with stainless steel thimble, this will really make a nice additional mounting point.
Will you also be able to use this prussic line and thimble to create a 2:1 Lanyard? I didn’t see anything listed for this in the literature, but I would think that it would be possible.
One other question that I have is, when you are using the lanyard and connecting directly to your center attachment point, does the carabiner connect directly to the becket below the sheave on the Pinto Pulley?
I can see where there will also be a nice feature if you are using a Hitchclimber Pulley with your DdRT, you will be able to use the third hole in it to attach the Pinto Pulley. This will give you only one streamline connection to your center attachment point, which is a nice feature.
