Anyone else having problems with new saws not running properly?
I've bought many stihls over the years and loved them, but some of these new ones don't run right.
Two of my newest saws I purchased this summer, a 460 and 440. The 460 runs good all the time, but the 440 is a pain in the ass. My brother also purchased a 440 this year and my workers said they used it and it does the same thing.
Here's what it does:
When you use the saw at 1/2 to 3/4 throttle; lets say to finish the last inch of a cut, or say to cut off a small diameter limb; when you let off the throttle after the cut, the saw dies. Then to start it again you have to usually use choke to pull gas into the carb to get it running.
This is the only time it dies. It idles fine, revs up fine, good power, good high speed. But it's just when you use it at about 3/4 throttle, the thing seems to get too lean and when you get off the trigger it dies, and dies fast. Even if you hear it dying you can't save it by pumping the throttle again.
Adjusting the high and low speed mixture screws doesn't stop this problem.
I've been meaning to take this saw back under warranty since the first day I got it. I figured it would have a year warranty easy. Well, I finally took it in on a rainy day. It's only covered for 3 months for commercial use, and it's been about 4.
Since I believed the mechanic wouldn't find anything "wrong" with it and it wouldn't be covered I didn't leave it with them. I think the new carborator just doesn't run good due to the changes they have to make for emmision requirements.
The only thing I can think that could be wrong, other than design, is that maybe it has a vacume leak if the carb isn't sealed to the cylinder correctly. I doubt this, because it has done this since the first day we got it. But maybe it wasn't assembled right.
I also hate how one of my 200Ts doesn't have a high speed adjustment screw on it's carb.
My first 044 was used just about every day of work (5 day workweek, about 10 months a year) for about 11 years. And was a wonderful saw. This new one has been a pain since the first day of work. I bet my workers waste an hour total in a day from starting it so much. Everyone hates to use it.
Does any company sell aftermarket performance carborators for stihl saws, like for the 440??? Or anyone have old 044 carbs?
Thank you,
Thank you,
