How do you put a swivel on a canopy anchor? One that is retrievable from the ground?The setup is more compact if you have the swivel version, eliminating the need for the bridge swivel (unless you need it for other systems/devices.). I've had ROOK pulleys and swivels on the bridge in the past, but didn't like the extra weight and clangy setup, so I don't use them, anymore. Instead, I use swivels or swivel pulleys elsewhere in the system (canopy anchors, for example).
I can't quite picture how it can swivel when installed like a R&R. I could see it working well in a pulleysaver type configuration though.Mine look like a ring-and-ring friction saver on steroids. Very large steel ring on one end, and the other end has a rope connected with or without a swivel (SRT) or a swivel/biner/pulley combo or an Omni-Block swivel pulley... they install very similar to a R&R FS but retrieve from a retrieval line (usually Yale Classic Slickline or 3/16" Dacron Poly or 550 Paracord) but almost anything will work just fine. I've never had any issues with the retrieval line being a problem or in the way of anything, and it's the quickest, easiest way to retrieve the anchor.
.The setup is more compact if you have the swivel version, eliminating the need for the bridge swivel (unless you need it for other systems/devices.). I've had ROOK pulleys and swivels on the bridge in the past, but didn't like the extra weight and clangy setup, so I don't use them, anymore. Instead, I use swivels or swivel pulleys elsewhere in the system (canopy anchors, for example).
Or skip the akimbo bc it's not time tested and the zig zags work on all ropes in the listed range (11.5-13mm) and I've had mine work on ropes thinnner and thicker than that range with no adjustments.Wecome aboard matey
Might I suggest looking to spend your hard earned dough on other devices that work more better. Something midline attachable that excels at both MRS and SRWP. Something adjustable for different ropes and climbers. Something new and blue.
.Or skip the akimbo bc it's not time tested and the zig zags work on all ropes in the listed range (11.5-13mm) and I've had mine work on ropes thinnner and thicker than that range with no adjustments.
I love mid line attachability but if you Kno what your doing, you'll be fine.
Reead up on the akimbo bc lots of guys do have problems using the ropes the manufacturer suggested.
My zz has a swivel but I believe I'd like the version without the swivel bc it's definitely stronger and I think I would be fine without it
Chicane is a horrible idea.
...thx for the reply.. as I said, I have looked at all, and have narrowed my choice dwn to the zigzag (jus don't think spider jack is worth nearly 2x as much).. I'm basically looking for actual hands on exp with this device and the perspective from persons that own and use it.. I appreciate your view.. I'm leaning toward the Pro version more due to it being a more compact unit overall and think that a swivel on the bridge to be more practical.. i.e. it's removable, or can be used as another attachment point & the diff in weight btwn swivel and the aluminum ring I use is 0.7oz/20g, which is negligible.. also if I add the chicane I'll still have the other attachment point like the hitch-hiker pulley.. not having any exp with this device was questioning in case there was other view point I haven't considered...
..re: the new blue one, IMO, it looks great on the drawing board..
IIIDaemon
...which version do you have..? And do you use a ring on your bridge..?
...I could see it working well in a pulleysaver type configuration...
...Chicane is a horrible idea...
Is this sort of what your describing? The hitch cord is the climbline, the hammock is your TIP limb. Obiviously in SRS configuration. Sorry for the bad picture qualityI have a version 2, 3 version 3 ones, and a version 4 one. I use an SMC ring on one harness.
I don't have a PulleySaver, but maybe it resembles that more than an RR FS... in any case, it installs very much like a RR FS. I install it with a throwline through the pulley, because I don't see the point in dragging the rope through the TIP during install if you don't need to. I install the anchor, then pull the rope through the pulley. To retrieve, I attach a retrival line during the install, and it pulls the very large ring down over the swivel/pulley/rope to bring it down. I pull the climb line out, first, and if I don't want to bomb the anchor down, I use the climb line to put a throwline back through the pulley to guide the anchor down slowly.
This is in the MRS mode. For SRS the climb line gets dragged through the TIP during install and retrieval, but at least it isn't loaded. Installs by pulling it up and through the TIP with throwline by attaching it to the retrieval line attachment point (large ring end). A throwline needs to be attached to tail of rope that is the same length as the rope, when using shorter ropes or high TIP. Once large ring is down, feed the tail end throwline through the ring, replace the first throwline with retrieval line, and use the tail end throwline to pull the anchor/rope up into position. Retrieval is the same as in MRS mode, just pull it down over the swivel/rope and down to the ground... reattach the tail end throwline if you don't want to bomb it down.
Stupid simple, works every time, nothing to break or go wrong. If a log lands on the retrieval line (which I've done many times) It does nothing. You can feel a little twitch in the rope, but it doesn't yank anyone out of the tree. Worst case scenario is that the retrieve line breaks and you have to replace it with something else or manually retrieve the anchor.
The Chacane is actually a very nice device, works exactly as it is supposed to, and works far better than trying to use a RopeWrench on the ZigZag.
.Here is a video comparing the new pro version to the old swival version. Maybe seeing these versions in action and side by side can help you decide. I was amazed how much larger the new version is.
.I don't have a PulleySaver, but maybe it resembles that more than an RR FS...
I guess he means that it engages right away, unlike the RW.Please explain you rw vs shitcan addressing half vs all of controlling friction
And it should work how it's supposed to.Chacane is actually a very nice device, works exactly as it is supposed to, and works far better than trying to use a RopeWrench on the ZigZag.
My Rw engages Everytime . No issues everI guess he means that it engages right away, unlike the RW.
Not that it doesn't engage, I meant the time it takes to set, or rotate down to add the friction. Not saying using the RW with a ZZ is a problem and doesn't work well, just that the Shitcan does work a little better.My Rw engages Everytime . No issues ever
