More gear
cthompson22
NY
Compact bulldog bone. This is one of the older styles with small tending hole and stainless links. It's just not for me. Only issue with it is you will need to contact Gordon for some extra pins for changing out the bollard or you might be able to get your own at a local hardware store. I used them all up switching bollards and I would highly recommend not reusing them. Either way it would be cheap to get replacements. The one in it right now has been changed multiple times and should not be used any more ( I only used it for testing low to the ground). Comes with all the extra bollards.
$200
Trango cinch in good shape red in color. $40
6 petzl ball locks 2 William 4 Amd all are in useable shape with minor scuffs and scratches. Not a whole lot of use on any of them really more marking from the gear bag than anything. I just have too much stuff and I never use these so I'm trying to thin down some of my stuff. $60 for the lot of 6. These have not been dropped or slammed around,I will get pics of any and all markings of each individual biner for you. If you are not happy send them back and I will refund your money. I'm real picky on life support gear so I fully understand, I would climb on them without hesitation I just don't need them and they are too clumsy for me when using the normal pull down and twist on all my others.
2 3 hole Ct rigging plates one is new the other was used maybe 6-8 times on a base anchor sling. $ 40 for the pair.
All prices include shipping in the lower 48 PayPal gift or +3% Pics available via pm just send email or cell #
That Trango is a good little tool. I've often been climbing with a small backpack stuffed with 80' of 3/8th'' static line. I use it as a tagline that can be thrown back down through canopy, but with the trango it also becomes a second climb line, that can, e.g., be thrown into a nearby tree.
