Help calculating load
I'm seeking easy equations or a calculator to figure shock load and swinging loads. I've found a fall factor calculator on a rock climbing site that works for the shock load, but I'm not sure the numbers are correct due to different definitions of static/dynamic lines and drt applications. Any help with this would be great!
You da man! Thanks!
Spidey's THE Man!
