I like using trucks and other heavy machines as anchor points, but how do you calculate the amount of force you're putting into your rigging and the tree, when you pull with a mini? Does the manufacturer supply a figure for the maximum amount of pull the machine is capable of, and then you factor in different rope angles to adjust that figure?
I'm asking because I've always been discouraged from using trucks, skid steers and minis for pulling on trees and rigging, with the reason given that you can't accurately calculate the amount of force you're cycling into the components of your rigging system and the tree. On the other hand, fiddleblocks and other manually powered pulling devices like the GRCS are said to allow you to accurately calculate the amount of force you're putting into the system, so that you can be confident that you're operating with forces below working load limits and also keep track of load cycles.
I like getting things done quickly and efficiently on jobsites, but I don't want to inadvertently cycle a rope to failure, or pull apart a tree I'm trying to rig out of.
