Re: \"Extreme Rigging\"
You've got it xman. Nice pics, thanks.
The angled lag is an idea, but then that is the wrong angle for the next piece, although it is the anchor lag that takes more force. And there is a higher risk of cutting them. I have tried it with a portawrap instead of a pulley to reduce anchor forces. Whatever happened to dave Spencers topping pulley? that'd work great here?
The discs can always be cut into 6" lengths to lower the weight and fall disatnce.
There is some fall force of course, but very little. With nylon ropes rather than polyester, this should be taken care of.
I like your idea of clipping to the lag below the pulley for safety.
For those that are getting to grips with setting the lags - thats easy. You do it when just a stick is left on the way down - swap the saw for a drill and lag spinner. Then have a cup of tea and a candy bar and SRT back up, haul the lowering rope and pulley, clip it and have the ground crew haul up the big saw to start cutting. Much easier than frigging with big heavy rigging.
This is an un tested technique of course. If TreeFlex sells OK, I'll be having some special lags made and drop tested to see where they rip or snap.
The dowelling rods are to keep the kerf open when cutting. One for either side of the bar makes sweeping a long bar out easier, and then you have nice rollers to slide the disc on to the edge (this is all based on ergonomics and reducing fall forces). Ken explained he used to use a chest pocket full of straws filled with ball bearings and their tops folded over. He'd blow the ball bearings into the kerf, then the cookies could be rotated wherever with ease.
The lags are really useful for loading onto a truck too - no struggling with slings, just clip the hook. I take the lags out at the yard on a rainy day/at convenience. Its not a technique you require every other day unless you make a name for yourself doing that kind of tree and have good climbers to rotate.
Try it somewhere safe with steel forged lags and let me know how you get on.
