Damn sounds like it is
your saw (am always uncertain when I hear 'bosses', the bosses I've seen supply saws to their own staff but not to me when I do per-climb jobs for them, it's basically expected that I come w/ my own everything - which I prefer - but have never seen a company having their climbers buy their own saw) If you're not dead-set on Stihl, the echo 355t is only $350 and is nearly identical weight and horsepower to the 201t (don't wanna get into arguments but anecdotally it seems the 355's are better off-shelf, and it's certain the 201t's are better
if you go getting the jug modded) and you get 1yr commercial-use warranty, also you can use it for 7d and still return it if you're not sold on it ;D Note: the carb will be set very lean and should be adjusted, also the OEM b&c is dogshit you'll probably want to go to Monkeybeaver for the 1/4" pitch sprocket and accompanying Panther b&c, if you're used to Stihl B&C's...can't tell if I'm envious of Stihl b&c's, or if I'm only experienced with sub-par, homeowner-grade b&c combo's (have never gone and bought pro chains, I just buy new, cheap chains whenever mine are done, need to figure out a better approach here
