I am going to get it...
Small DMM = 4,500 WLL rating
-my 3/4" loopie sling = 3,360 WLL
-my 5/8 Stable Braid = 3,300 WLL
I figure the block will not break!
p.s - TH, I hope this 'small' block does it for me. The 'BIG' block is rated @ 6,750 lb safe working load. Whew!
unatool,
The small block has a WLL of 40kN ~9,000 lbs.
Large block is 60kN ~13,500 lbs.
I imagine you are getting the point across that the block will see potentially double the force of the load, hence the 4,500 and 6,750 numbers. However, it is important to quote the actual WLL as the rope angles will always change based upon the particular configuration of the block.
Also, just a reminder to us all, we need to keep in mind that a WLL is calculated for static load
and dynamic load. Neither the static nor dynamic load on the block should exceed the WLL.
