I have a bad codominant fork in a tree in my backyard. If it were to split, worst case is some damage to adjacent trees; no structures nearby. Anyhow, I'm considering taking off the left side. I may rig it to a line coming down from the tall pine to the left to (1) maintain control of it and be able to lower it and (2) be able to pull upward tension on it when cutting to help avoid pinching my saw. I'm thinking of making a broad notch and slowly enlarging it until it's cut through since there's no room for a saw between the stems at a height that seems safe. Tree is only 6" dbh and forks at 15'. I'm thinking the final cut should be at about 45 degrees. Opinions on that, or the best way to cut and not get pinched?
