Anyone else have the cable winch on their chipper with the skidder style choker setup? How do I shorten it up a couple inches past the part that's frayed? Has a fat piece of metal on the end that the cable looks like its crimped inside of.
I would if it wasn't only the last 2" of the line . Midline fray would be switched out for amsteelPull it all off and replace it with Amsteel...
Our SOP is that the winch line is attached to a log or put away if the feed wheels are going. With that simple rule, you will never have a line sucked in with hardware on the end.Train everyone in Stop, Drop, And....
If those ends ever get sucked into the chipper lots of extras will be coming out.![]()
... Has a fat piece of metal on the end that the cable looks like its crimped inside of.
What's the point of this extra hardware? Put a hook on the end of the line and clip it over the line to choke the log. Why spend money for extra hardware to complicate things. I don't get it.I bought the hardware on the no knot winch that tree stuff sells. This is hands down the way to go for winch lines/hardware. Dummy proof. I already had a nice amsteel line so I found another vendor to sell the hardware. Check out the tree stuff link.
http://www.treestuff.com/store/catalog.asp?item=15247
I found the gates on the clips always getting bent off. No matter how many times I told the guys how to orient the gate, they would break them off. You can still use a snap without the gate but its not as easily used unless constant tension is kept on the line.What's the point of this extra hardware? Put a hook on the end of the line and clip it over the line to choke the log. Why spend money for extra hardware to complicate things. I don't get it.
