Jehinten
- Evansville
I'd be hesitant to think it was the controls, since this problem occurs with both the pistol grip and the ground controls. Are there any safety switches that come to mind that I should look for? The boom swings a 360° so there shouldn't be a limit switch, and I can hear the engine accelerate and the pump engage. So it seems to me the controls are calling for it to turn.
My thought process (Although uneducated in these matters) tells me it's either to heavy of fluid (although this would only be, if this one function was more sensitive to it than the others) or maybe the hydraulic motor that rotates it is going out.
I have found that if I assist it it will work most the time (push/pull on tree limbs while running controls) otherwise it's sporadic, sometimes it works and others it won't. Or will stop mid swing. Started doing this all of a sudden when I was putting my boom away after working on a removal.
