Best grapple for swing loader
My chipper weighs 4400, but very little tongue weight when the tongue is horizontal. It goes up quick as the tongue goes down. My mini is 2680#.
Do you have an idea on your tongue weight, Ryan?
How much can you move your chipper to your work, leaving mulch in place for landscapers (with verbal or, go crazy, written instructions) or you performing root zone improvements at arborist prices?
One of my soapbox speeches is about how proper mulch and watering are the tree's best friends, and ground-level work. I rarely haul chips to the point that I'm frequently short for personal use.
The red wine glass on the dinner plate analogy is a favorite way of explaining root zones, along with looking at their tree and pointing way over there 40 feet from the trunk, and way over there, and there and referring to "your doug-fir" or "your maple" forcing them to consider the root system.
I think of buying a bunch of deep root irrigation needles and giving them out to customers. $25/ each
I like taking the chipper to the material with the mini. I have towing coupler universal plate, but frequently use the BMG grapple. I have a bolt-on-the-tongue swivel caster, 450# capacity, 12" tire that I've used a bit, but generally don't use it. Tractor Supply company ~$40-50. I've used it to spin the chipper 180 degrees to shoot chips where needed.
People don't want 5000 pounds of mulch far away from where it is needed nearly as much as if it is right where it's needed.
Works great for MY market and my tree-hugging customers.
@flushcut says that scoops move chips well, and a log spreads them well.
I clean up all my stumps with the scoops and grab a log to make a plow for spreading chips if need be. I’ll grab a log and use that to push debris towards the chipper. It works best on pavement, grass not so much. The trick is to pinch the log with just the tips(lol) of the BMG and not clamp completely around the log. About a 14”ish diameter log 8-10’ or so works best.
I clean up raking piles as well with the scoops, real slick. We chew through snow banks with them to gain access in winter. BMG and products FTW!
