CutHighnLetFly
Been here a while
- Cape Cod, MA
So disclaimer to this thread, techniques discussed here should not be tried in a "f*** it, let's try it" kinda setting because a lack of understanding of concepts by climber and ground guys could leave you getting wrecked.
What are people's preference of cut when one is trying to rig a limb to turn/swing 90* from the ground, swinging it over an obstacle (roofline, porch, etc)?
I'm talking without a spider leg. I never feel I need one and never use them. I balance tie. I'm torn between a nice wide notch and a thought out snap cut.
I think the snap cut requires more skill on the groundmans work, as it's more likely to pop free, potentially causing the butt to push back towards the tree. The notch is more controlled and predictable but moves slower and I think harder to play momentum because of the hinge.
Just curious what others think and do, like if I should just rock the spider leg, if it makes things that muh easier. Im pretty good with telling where's best to tie off tho....
@Pfanner man not to drag you into threads, but your input is of value, your rigging in videos speaks for itself.
