OasisTree
- Central Missouri
I have a Rolair 60 gal. for my shop. I have been happy with it so far.
Working for a new company now or yourself? (If you already shared the info, I missed it.)@Serf Life id say at the moment I’m comfortable around 500. My research has just started, and at the moment I’m slammed with storm/wind damage work.
I’ve got my own thing going on, along with contract climbing. I should’ve made the move long ago. Knocked out my first crane job as a business owner last week. Extremely gratifying because it was nearly in my own back yard, it went extremely smooth, and I got the job over the other companies.Working for a new company now or yourself? (If you already shared the info, I missed it.)
Heard anything about how your former employer is getting along? I'll shed a tear for him if he's struggling to replace you. Not!I’ve got my own thing going on, along with contract climbing. I should’ve made the move long ago. Knocked out my first crane job as a business owner last week. Extremely gratifying because it was nearly in my own back yard, it went extremely smooth, and I got the job over the other companies.
CongratsI’ve got my own thing going on, along with contract climbing. I should’ve made the move long ago. Knocked out my first crane job as a business owner last week. Extremely gratifying because it was nearly in my own back yard, it went extremely smooth, and I got the job over the other companies.
Way overkill for what you're looking for probably pretty questionable quality as well. Any of these should work just fine for you that 350$ 2hp 4.3 cfm is a beast, they're light to if you ever need to move them around. If you really want gas that 5.5 hp 9 gallon would be capable of just about anything and it's a higher quality lower cost unit than the one you linked.NorthStar Portable Gas-Powered Air Compressor Honda 163cc OHV Engine, 20-Gallon Horizontal Tank, 13.7 CFM @ 90 PSI | Northern Tool
The NorthStar® 20-gallon horizontal gas-powered portable air compressor is built for heavy-duty applications and l...www.northerntool.com
Would this be gross overkill, or not enough? Choosing a compressor has been much more challenging than I expected….. It’s a lot to spend, but I want good gear that will accomplish what it’s intended for, and will last. It checks a lot of the boxes.
That compressor should do everything you need and plenty more! I don’t know who builds the compressor (the actual air pump) but the Honda engine will last forever, and 13.7 CFM at 90 PSI is as much or more than most big shop compressors put out. If you want that style compressor and want one that will definitely last forever, look at a Jenny. They’ve been in the construction compressor business forever, they also build/built the Emglo compressor, which every construction company in the world probably owns.NorthStar Portable Gas-Powered Air Compressor Honda 163cc OHV Engine, 20-Gallon Horizontal Tank, 13.7 CFM @ 90 PSI | Northern Tool
