I try to have my groundmen run the rope from near another tree. This way if they have to little wrapping, they can get a quick 1/4, 1/3, 1/2 wrap around the other trunk. I've only had two times that people have under wrapped, usually its overwrapping.
I'd rather splatter a shrub, or even a house, than myself get hit by a locked off log.
Good communication back from the ground is sometimes not present enough. As a climber, I think that its important to know how easy or hard it is to catch or hold a piece, allowing me to calibrate my cutting better.
Call and respond can extend from such things as "Come under?", "You can come under."
to
"This piece is larger than the first/ last piece, and is rigged above/ below/ to the side of the block (sometimes hard to see way up high accurately). Let is run. Stop it above the roofline with a soft catch/ let it run till the tips hit the ground, but don't let the butt flop."
Response: "Larger piece than last piece. Letting it run with a soft catch/ snub off because of target below. Piece is coming from below block, with low dynamic loading!"
Twice, I was almost smacked by locked off loads because the groundie didn't let it run. The first time, I don't know what he was doing, the second time he had his head up his... and locked it off because he thought that I wanted it locked off, for ZERO good reason.
I should say ex-groundie (not just for that reason).
