- Bloomington, Indiana
LAZ, are you saying that instead of the traditional 6 finger prusik you opp for the VT?? I have been thinking about testing that out for myself. If you have used it before for a brake how has it preformed under a good load or shock load? Always looking for a new and better way. I hate how if for whatever reasone you have to slack a highline you need a load releasing hitch or MA on it still to do so. The VT the most I could see needing is a micro pulley in front of it to pull back on it. Also has anyone tested that factor, when taking the tension off of the line with a VT how much jump do you get out of it?
We've used a Prusik, Vt, Valdotain, and several other friction hitches for both the brake and as the attachment hitch to the main line. I don't think any friction hitch could be released under the tension generated by a 3:1, and certainly not by a 5:1, when used as either the brake or the attachment.
Can you explain a "...load releasing hitch..."?
