davidwyby
- PNW to SoCal
Yes, on these sketchy boogers. Siberian elms again. The hollow plus codominant didn’t click as soon as it should have though. Should have just cut the stems off with their lean.Be careful. Do you do any kind of tree assessment before lighting into it with a saw? Smacking the trunk a couple of times with a axe or mallet is an easy way to detect hollows. But being it was rotten and not hollow yet there may have been other signs, insect litter, shrooms, slim flux, are a few things to look for.
Likely my least favorite tree to work, especially dead. I can taste the dust nowSiberian elms
Yeah, I could tell it was hollow as soon as I got half way around. Problem was my brain said, “Ok, hollow, faster cutting”, instead of, “Danger, Will Robinson”.Simply boring into the trunk can tell you a lot of what’s inside the trunk.
I always [refer to take them one a t a time when possible... If not set up the pull line to suck them together etc.Yes, on these sketchy boogers. Siberian elms again. The hollow plus codominant didn’t click as soon as it should have though. Should have just cut the stems off with their lean.
I always give a hard whack with the back of an axe before putting in a face.Yes, on these sketchy boogers. Siberian elms again. The hollow plus codominant didn’t click as soon as it should have though. Should have just cut the stems off with their lean.
Lucky diaper.You must have been wearing your lucky pants that day. Good thing that lead wasn’t too heavy.
Or just bring a sharpie and mark the bit when you detect the rot. Mark the bit, pull it out, and measure.On the human resistograph drill bit - maybe red nail polish (durable "paint") on the first 3" of drill web, next 3" orange, another 3" yellow as a visual "how deep is the shell/good wood" gauge. an idea
Same. Extremely rare. But they can get a bit punky and don't hinge reliably at times.We remove a lot of Siberian Elms here in Detroit and it is rare in my experience to encounter a hollow one, or even a cavity.
