Replace this rope?
ClimbingTN
Columbia
It got caught on a twisted tornado spar and I stupidly pulled it out. I haven’t looked for the book explanation. It’s Samson Silver Ivy 11.7. Should I stuff the picks back in, melt them or now it’s a bull rope?
Did the same nick job on a kernmantle rope two days ago - one strand cut thru with a couple more fuzzed and you can see the white core - but since it's a kern rope I decided this morning to do a chop job - lost 23' and now have a 97' (lanyard???) with no more sewn eye splice. But I hear shorter climb lines are all the thing now in some parts . . . . . What was the line from the movie Ronin - "If there's any doubt, there is no doubt" ! My own birthsign is the Cringing Chicken though.
I agree with if it gives you cause for pause, you should probably just replace it. It might be fine on paper, but peace of mind goes a long way at height. But, being the optimistic fellow I am, this is a good opportunity to build a new lanyard system!
Also, if you can see the core, that’s always when I switch mine. Or cut them down into smaller climb lines.
Silver ivy is a double braid with a 6,500 lb MBS. Half the load is on the cover. Half the load is on the core. Even if you completely sever the cover, that rope will still hold 3,250 lb. The little bit of damage in your picture would not worry me. I'd be more concerned with how that section runs through whatever device or hitch you're using. There's potential for it to cause a little jump if you're running a pure mechanical which could potentially lead to another little accident. But as far as the damage of the rope goes, if you don't want to use that rope anymore, I'll send you my mailing address.
I wouldn't worry too much, but when I first started out, I did replace ropes even less damaged than that because at that time, it made me uncomfortable to see whilst aloft. I have seen so much work done with much skankier ropes than that.
Out of curiosity, anyone know of an accident involving a rope actually breaking (not being cut)?
I have heard it said that it hasn't happened with a synthetic rope. It was one of the legit concerns using natural materials, and why there are such large recommended safety margins when it comes to life support.
