macrocarpa
- Midwest
Anyone out there using an inversion table? If so, what is your experience with them? And what injuries are you using it to manage?
Cool!I've used them for what I'd call a pinched nerve from a bad lift. Haven't needed it in a decade.
Any amount of inversion can feel good, 15-20⁰ below horizontal gives light traction on the spine.
A board on a slope padded with a blanket is a start. Knees bent over the top of the board, to keep from sliding.
My hill is sloped about 20⁰. If I just lay down in the right direction on the ground, it's the same as a table right?I've used them for what I'd call a pinched nerve from a bad lift. Haven't needed it in a decade.
IMHO, absolutely get massage work, too.Cool!
I have a pinched nerve at L5S1 from overworking/lifting while working on my house in mid Dec. It hasn’t bothered me in over 15 years until now. I had a great tree season, but then over did it working on the house when tree work slowed down which was just stupid. 3 weeks + in and it’s slowly improving. I don't bounce back so fast anymore. My doctor recommended an inversion table to get some space between the vertebrae to suck that disc jelly back in. He said it’s like a peanut butter and jelly sandwich and I need to get the jelly back in the sandwich. Luckily my wife is a physical therapist and has me doing exercises. I think I’m going to buy an inversion table and hope it helps. Also start with the Chiro next week.
It sucks! But luckily it happened during the slow season.
YesMy hill is sloped about 20⁰. If I just lay down in the right direction on the ground, it's the same as a table right?
I did one massage session so far. $75 / visit though. A local lady here we like does some cranial sacral stuff too as well as the usual. She really dug into the nerve going from my back to my foot. It helped with my agility for sure and slightly reduced the numbness on my foot.IMHO, absolutely get massage work, too.
Not necessarily. The point of an inversion table is to 'hang' your weight on the ankles or feet so that the head and shoulder weight stretches the joints - the opposite of the compression the joints get all day long. Laying on the ground won't do this if there is a lot of friction between the ground and the head, shoulders and hips. There needs to be something holding the feet/ankles in place so the rest can stretch.My hill is sloped about 20⁰. If I just lay down in the right direction on the ground, it's the same as a table right?
That makes senseNot necessarily. The point of an inversion table is to 'hang' your weight on the ankles or feet so that the head and shoulder weight stretches the joints - the opposite of the compression the joints get all day long. Laying on the ground won't do this if there is a lot of friction between the ground and the head, shoulders and hips. There needs to be something holding the feet/ankles in place so the rest can stretch.
This is the biggest point to emphasize. How much does down time cost? Enough to take care of yourself usually.Acupuncture, massage, and adjustment. Life is too short for back problems. Seems like a spendy visit, but multiple days on the sidelines is very spendy….
Money well spent.I did one massage session so far. $75 / visit though. A local lady here we like does some cranial sacral stuff too as well as the usual. She really dug into the nerve going from my back to my foot. It helped with my agility for sure and slightly reduced the numbness on my foot.
Yes, it does require what you said. I wanted to suggest that you don't need to buy and store an inversion table to get benefit, as it can be enough traction at a lower angle, which will be gentler on joints, as well as less extra blood to the head.Not necessarily. The point of an inversion table is to 'hang' your weight on the ankles or feet so that the head and shoulder weight stretches the joints - the opposite of the compression the joints get all day long. Laying on the ground won't do this if there is a lot of friction between the ground and the head, shoulders and hips. There needs to be something holding the feet/ankles in place so the rest can stretch.
I’ve been doing that from a pull up bar in my basement. I do feel it works, but mostly on my upper to middle back. My chiropractor says your muscles never fully relax enough for the lower vertebrae. I’m still thinking about ordering an inversion table.Something else to consider is traction gained the other way, by hanging from a pull up bar. There are many benefits to simply hanging - active hangs, shrug pullups and tons of pull up variations that can really decompress the spine, build strength and fitness.
What do you mean you went to a tornado? Forgive my ignorance if it's a popular thing.You might be well off to use both an inversion table and a hang bar.
I went to a tornado and tweaked my back. Bought one that day. It was well worth it!
I figured it must have been a typo. Thanks for clarifyingPoor edit on a magic human rectangle without proofreading.
I went to work after a tornado hit my old college town. Doing storm work, I tweaked my back.
