Steve,@rico "When I am taking bigs tops I usually open up the intersection of the undercut to keep it from closing for as long as possible, and if i am really worried i will use a modified coos bay." Sorry, whats a coos bay?
Better terminology.I would say it's a strip of holding wood, no hinge in a Coos Bay.
Fundamentals of General Treework introduces it.
Very useful!
100%.. he was way low on that back cut, only after putting in a very shallow notch, and then he stopped in the middle of the cut... Recipe for disaster. He hit the trifecta... Beyond bad skills.. that's doing everything wrong that you possibly could do wrong. Hope he found something else to do for a living.It's really hard to tell, but it kinda looks like he undershot his back cut by multiple inches. If so, this top had no choice but to do what it did.
A very shallow undercut, a severely undershot backcut, and a fella who is taking his sweet time on his backcut. No wonder things turned out as they did. Duh.100%.. he was way low on that back cut, only after putting in a very shallow notch, and then he stopped in the middle of the cut... Recipe for disaster. He hit the trifecta... Beyond bad skills.. that's doing everything wrong that you possibly could do wrong. Hope he found something else to do for a living.
sketchy top no matter what, but he clearly gave it no chance to do anything else... but hey... that's what angels & funeral directors are for... Looks like the angels beat the funeral directors out on this one.
And that topping cut could have easily been made safely with the right cut, but why take a chance?.. wrap that bad boy up with a wratchet strap or even multiple wraps with a short piece of accessory line. I wouldn't have used one, but if you're not 100% confident in your skills, that's the fool-proof technique.
Did you see this one? @rico I only came up with the idea because I was trying to induce a BC with a pull line and the codom behind it kept it from splitting..
and here is the fall:
There are times when taking a large tops is the safest and most efficient thing to do, but that is assuming the person in the tree has the experience to be making these cuts.
Modified coos is putting a face in, correct rico?@rico "When I am taking bigs tops I usually open up the intersection of the undercut to keep it from closing for as long as possible, and if i am really worried i will use a modified coos bay." Sorry, whats a coos bay?
This was a modified coos bay..
So you were the first cutter on the internet to post big tops, to your knowledge.
This was was published in 2009.. to my knowledge this video was the first ever published showing big tops..
Did I miss a segment?
CHeck the date.... May 22, 2010So you were the first cutter on the internet to post big tops, to your knowledge.
I see a tree felled using only a plain ol' back cut. Then the feller stands right next to it while it barberchairs.
This had a good ending...no one was hurt.
Is 'modified Coos Bay' or MCB a high falootin' name for Make Back Cut or MBC?
