Matias
- Butte County
so many good points being made here. Feels like I’m getting more than $0.40 worth.
Some good points.Standing in spurs all day is hard on the body.
I tell my apprentices that staying uninjured is non-negotiable, and sitting in your saddle is ergonomic.
If you're using a lanyard, you're tied in twice, so it's not life or death if you cut your rope.
That being said, don't cut your rope, obviously.
If cutting a rope that is extending from your bridge to the tree is that much of a consideration, maybe they are not ready to be climbing.
Hanging from a rope reduces steps on spurs to reach the back side of the stem for limbing..ergonomic and productive, IME.
I basically started SRS (F8 revolver/ wooden rope wrench, pre-ZK1) choked below a steel core lanyard about 14-15 years ago. Way harder on the body than hanging. I've utilized the overhead TIP for a long time.
Pacing is important. My body needs to last for my entire life.
$0.02
Very good points, you’re right, Sean’s right and even I may occasionally stray into the domain of the not entirely wrong.Having a higher tie-in is wonderful when it is possible, and practically necessary when working on larger trees that require moving around the trunk to get limbs. That said, in my area I'm often working in tall doug firs that don't have many, or sometimes any, limbs large enough to be a safe tie-in because the trees are so close together. 70' trees with no limbs larger than 1.5" is common. Throwing your line above you before cutting isn't a safe option in those cases. And even when it is, if/when I spend the time to do it, is the extra time on spurs that takes actually less strain on the body than not doing it, but spending significantly less time in the tree overall? Sometimes yes, sometimes no.
