Tom this is from the USFS manual you linked... I copied and pasted, but had to clean up the grammar due to the change in format..
Cabling and Bracing Defined:
Cabling and bracing is the practice of adding a support system to a tree to reduce the stress on weak branch unions. Many trees have acute, V-shaped branch unions that form included bark. Included bark acts as a wedge that weakens and separates branch unions that join at too sharp an angle. A similar situation occurs when two equal-sized stems form off the main bole of a tree after the loss of the main leader. The bark of the two stems push against each other and the two leaders do not have a strong connection to the main bole(Fig 5.11). As the tree grows, these structural defects can lead to the failure of one of the two stems. Adding properly installed cabling and bracing will reduce the strain on the branch union, and extend the life of the tree.
Cabling and bracing can also be used to correct trees with poor architecture. Typically, as trees grow, the trunks and limbs taper toward the ends. This tapering reduces the strain on the higher and outer limbs in the tree. If limbs and trunks do not taper, a large amount of leverage acts on the point of attachment where the branch meets the stem, which can lead to failure. Improper pruning can also place strain on branch unions. The inner branches of some trees have been removed because of the mistaken belief that such hyper-thinning eliminates the possibility of wind failure. Actually, by removing these inner branches, the tree will put on more length and less bulk in its limbs. This leads to the condition referred to as “lion’s tailing.” Because the limbs are long and thin, but still maintain a full complement of foliage, the limbs will whip severely and possibly fail, instead of swaying naturally.
There are many considerations that must be addressed before a cabling and bracing system is installed in a tree. The tree may have a high value in a particular landscape, or it might be a historic or unique specimen. Before investing in a cabling and bracing system, the cost of installation and future maintenance must be balanced against the risk of failure and possible loss of aesthetic value during the tree’s extended life. Carefully assess the tree to determine if it is a reasonable candidate for investment in cabling and bracing. Consider the whole tree during this assessment. The roots must be strong enough to support the tree. If there is decay in the main trunk or branches, factor that information into the decision to remove or save the tree. If the tree has cracked already, the arborist must know how well the tree species in question is able to compartmentalize decay. Some trees can isolate decay better than others. The outcome of a decision to apply a cabling and bracing procedure to a white oak(Quercus alba) may be completely different than if the tree in question is a basswood.
Remember that cabling and bracing do not repair a tree. Cabling will add a level of security and risk reduction and can help to affect the direction of failure if a branch should fail. When designed properly and installed by a trained arborist, proper use of cabling and bracing will extend the life of a tree and reduce the risk to an acceptable level. If the decision is made to use cabling and bracing to extend the life of a tree, it must be understood that such treatments are temporary. Give consideration to planting a young tree or trees to be used as replacements if the cabled and braced tree is removed.
Some trees will benefit from having weight removed from the branches before the installation of cabling and bracing hardware. Therefore, do all necessary pruning before the tree is cabled. Remember, removing major lateral limbs creates large wounds that can lead to extensive decay on the main bole of the tree. If weight reduction is determined to be necessary, a slight crown reduction by using proper thinning cuts in the crown is the safest course of action. The possible harm from over-pruning a tree to remove a significant amount of weight must also be recognized. Most trees will need only routine pruning to remove dead limbs and other material in accordance with accepted pruning standards as discussed in Chapter 4. Inspection Schedule.
Once a tree has been cabled and braced it is necessary to inspect the tree on a routine schedule. The size, age, site, and risk potential of the tree will determine the inspection schedule. However, no cabling or bracing installation should ever go more than two years without inspection, and annual inspections are a good idea. Some inspections can be done from the ground. Binoculars can be used to make a more thorough inspection of the tree without having to climb it, or use an aerial lift to inspect the crown. As time passes, it will be necessary to have an arborist inspect the anchor points and any changes in the tree’s growth from within the tree.
There may come a time when a new cabling and bracing system will be necessary. Again, this assessment will need to be done by an experienced arborist following the same procedures as in the first installation. As the tree grows taller, the time will come when a new system should be added, higher in the tree. Do not remove the old, lower system before the new system is completed. Do not attempt to remove old hardware embedded in the tree. That will unacceptably damage the tree. Cut such hardware flush and leave it in place.
Liabilities. Cabling and bracing is a practice that, when properly applied, can extend the life of a tree. In addition, cabling and bracing can reduce the potential for failure to an acceptable level. Once a tree comes under an arborist’s care, the arborist is obligated to follow accepted trade practices. During the inspection, the arborist may determine that the removal of part of the tree is a better option than cabling and bracing. Care must be exercised in this case since the removal of large portions of the tree can lead to conditions that could lead to tree failure. If the risk of failure is too high, then removal of the tree may be the best option.
Since cabling and bracing have a long history of use and is an accepted, standard practices, the concern for additional liability should be little different than if the tree were being pruned. However, the correction of defects by cabling and bracing requires additional inspection and maintenance that must be performed regularly to ensure the integrity of the procedure. Failure to perform regular inspections, and to correct any problems that may arise, may indicate negligence. Choosing not to install a cabling and bracing system because of a fear of liability is not a good decision. The best procedure is to follow a plan that reduces the risk of failure to an acceptable level.
