Burrapeg
Been here a while
- Puget Sound
We were discussing these things over in rec climbing in a thread about climbing without a lanyard to save gear weight, and Tom suggested a separate thread about it since they seem very useful. Several brands of these so-called pack wheels are available for hiking with heavy gear loads, but none are cheap. I am addicted to tinkering, and I thought of my old mountain bike I had quit using. It was the work of only about 20 minutes to remove the handlebars and front fork from the frame, re-install the handlebars on the fork backwards, and install the rack from the rear of the bike. Result: a basic pack wheel. These will negotiate much narrower and twistier trails than a wagon or two-wheeler, and can still easily handle an impressive pile of stuff lashed to it. I have used mine with as much as a hundred pounds of rope and gear several times, when I had to hike quite a ways to a tree. At 69 years old, I can't handle but about 30 pounds max on my back any longer, and even that is tiring. So this contraption has been very useful. Some of you have suggested an improvement that I am going to try to make, a long, V-shaped kickstand that will allow the wheel to be parked upright. In the past, I have simply locked the brake (off a baby stroller) and leaned the handlebars around a tree, even using a bungee at times to hold it there. But a kickstand would be great. Also, I have toyed with the thought of motorizing it for uphill work, using a rear bike wheel with the free-wheeling chain sprocket somehow with my big DeWalt drill off my DIY modded RollGliss power ascender. The DeWalt has three speeds and each speed is variable at the trigger, so one would have a very wide range of choices to suit any grade or conditions. Anyway, here are two photos of the prototype. I have a second, nicer one I made for my girlfriend, with new panniers and a white tire. Very handy for picnics and camping too.
