Def gotta make sure nothing gently touches that trigger at all. Like a twig or one’s own thigh.Works great for me. Def gotta make sure nothing hangs up on it though!
Thx! Yeah I bailed out of the YouTube circus a long time ago.AJ thanks for the videos. With my Captain "traversing rig" (see a link above), I had used wrench tethers and TreeStuff's shorter mini wrench tether with a buncha different hitches but found, apart from sap seizing up the hitches I've talked about elsewhere (the Zillon is not so affected by sappy rope - admittedly not so much of an issue with decurrent trees), it's more compact. Like in your video, I've had at times three tie-ins on the go and I just found it reduced clutter a bit, besides being really smooth to work along with a foot ascender to pull you along. Also I like the Zillon with a 3:1 to pull you along because in my own warped imagination it was kinda less "floppy" somehow than a wrench setup when out in a more horizontal-wards direction. Some of my thoughts for this Sunday AM. Again, thanks for the videos (great to see you on Vimeo 'cuz YouTube has gone CRAZY with all their stupid ads/ interruptions).
Adjustable Compact Bulldog Bone is excellent on 10mm hook line. Lot of people like the Akimbo. Either are more expensive than most people want to pay for a hook line adjuster/multicender.It is indeed "very giant" as its name... its interesting tho .
What's the best device combination for Cpt hook Progress capture and some small rigging purpose ? I wonder....
madrock.com
Yep, price of all the very good multicenders is not a good match for Hook use, unless (like me) your Hook gets a lot of use in daily climbing. Even so by my criteria the multicender needs to work with 10 or even better 9mm lines. I’m getting long accurate throws using 9mm. Also, has to be a straight path through the device for me or no deal. I put a lot of hook hours on the Trango Cinch, great device but any of those belay devices are a eventually a PIA if you use the Hook regularly. I think wear is not a major issue for multicender devices. Relatively short line, no big rappels out of trees.Yes, compact bulldog is very attractive but its pricey. I already own RRP & HH2. so, I just wouldn't wanna go for an third ascender just for Cpt hook uses. As you mentioned it is bit too much for a hook line adjuster/multicender. Akimbo, I would not want to go for from the get go . Any mechanical friction base device will wear out and Akimbo seems easy money grub and leave the rest of climbers.
I'm thinking of something like midline attachable toothless cam progress capture pulley systems. I'm still looking for something compact and durable for long time uses.
I don't think he's saying that they wear too fast or aren't worth it just that you almost can't wear one out using it with a captains hook. Not really sure what you could do besides a friction based device or that I would want one, only being able to come to a dead instant stop bombing out of a tree sounds pretty terrible. I don't have any experience with the akimbo but I have a decent number of hours on my RRP and it's made me many times it's cost back and still in good shape.Right .
All those multiascenders relies on frictions and they aren't really tough enough for long term uses so wears out so quick .
I mean ...Akimbo is like ... LMAO I don't know what to say. $400 disposal tissue papers in a way ... Pure greed . LoL
Compact bulldog is also wears out fast thats I've heard. I mean are they really not thinking how much our ropes gets flattened and touches side walls ? Creating another friction parts to apply breaks but often they won't allow us to make any part exchange for wear out replacements... But to buy them completely brand new .. C'mon...
Well, at least with bulldog you can order replacement parts. that's a decent business stance.
Yes , I was also looking into Trango Cinch . Now, it's called Vargo Trango ?
I wonder when people comes up with device that is compact , Sap/gum strong against , no teeth , doesn't rely on frictions, apply frictions so evenly on ropes or at least can change it's all the parts when where its wears out and obviously most importantly ... Safe...
Yep, you’re not going to wear out an Akimbo out as a hook line adjuster ever. Bulldog Bone is super wear resistant in regular climbing use and wear parts are easy to replace.I don't think he's saying that they wear too fast or aren't worth it just that you almost can't wear one out using it with a captains hook. Not really sure what you could do besides a friction based device or that I would want one, only being able to come to a dead instant stop bombing out of a tree sounds pretty terrible. I don't have any experience with the akimbo but I have a decent number of hours on my RRP and it's made me many times it's cost back and still in good shape.
Yep, you’re not going to wear out an Akimbo out as a hook line adjuster ever...
Key point! Gear can be moved around and used for different purposes at different times.Plus you can take it off the hook line and transfer it to a second climbing line in just seconds.
Yep. Easy finger-tip adjustment with a hitch-based mini multicender makes the hook more versatile and appealing to use.There already exists a device which can apply pressure to the rope evenly around all surfaces, is cheap to replace, midline attachable, etc. It's a hitch. 8mm HRC works awesome on the 10mm hook line, paired with a tending device like a pulley or the Shizzl. The only weakness of the hitch is that it doesn't release perfectly when it is carrying most of your weight, but for most users the frequency of that being the case is pretty low. Even when that is the case, there are usually ways to mitigate the problem like using your other hand for friction or to reduce weight on the hitch, using an 8 or a munter, etc. I've been using a hitch on mine for a while and it works great, but isn't perfect. I think there is a reason @moss has opted to create the mini wrench, and that reason is that it makes the hitch a near perfect solution.
Exactly... So, naturally overall, it's not just gonna be used for Hook adjuster after all. We can clearly see that coming .
I wonder progress capture, small rigging capable , strong against on saps , gums, toothless, applies even wear on ropes , compact , mechanical device that is quiet , midline attachable, all the wearable parts are exchangeable, mechanical device ... As moss states, "The Ghost" progress capture devices !! LoL
Lots of great ideas, combinations coming out here !
That's exactly what I had in mind for myself when I get my hook, as I bought a second zillon when I thought my first was stolen.Last winter I built out one of these with a Zillon and some Director biners/ swivels and a Captain. It is smooth as butter and doesn't seize up with sap, ever. Although the Tachyon is a bit heavier and gave me pause at first it seems easier on my hands and it is easier to twist and fiddle for retrievals than the 10mm from DMM. For me it's a sweet spot. Cheers.
What do mean? Have you seen the setup in ghostice's video?Zigzag is too big for it to use with Cpt hook ?
