Is this tied wrong?
Wrangler
Woodbine
This picture is from TCIA magazine this month issue features articles on rigging. I always though the tail was supposed to exit half hitch going away from the bight?
The tail is exiting away from the bight. What you are seeing is the half hitch which is required as a backup to finish the knot, although I do believe there are supposed to be two half hitches. I would still consider this tied wrong as a cow hitch is still directional. This being a block and the force pulling down, the first wrap around the terminating end should have come from the bottom up, not from the top down.
I had a question about that article too. It says the cow hitch is in basket configuration and doubles the strength while also stating it is effectively a girth hitch. I thought cow hitch was a girth hitch configuration which would be less than double?
I would think of cow hitch as closer to choker configuration than basket configuration
This is how I’ve been tying cow hitch for blocks. I add one or two more half hitches to finish. Is this correct?
Also should successive half hitches be in same direction or opposing?
What is the correct finish?
Two half hitches in opposite directions
Or threes half hitches in successive direction?
I’ve heard both
That’s what I’m wondering, what are the details that make a difference with this knot? I have never had a problem with it loosening , has anyone else?
You are all right! Many details here. In my in-field experience, the half hitch direction does not make a difference in strength or stability when the knot is loaded normally. years ago in some very unscientific knot breaking sessions, I found the same. I mention those sessions not as proof of anything, but I did notice the cow hitch did behave in breaking much more like a basket hitch, than a true choked configuration. I always attributed this to the amount of rope in the not comparably.
Futhermore, years of teaching in the field have led me to describe the cow hotch as more basket than choker. Seems gals and guys just seem to grasp it better When describing how to tie and how to load the knot. I would agree in it truest form it is a choking type knot.
However, much like breaking sessions those fine details make little difference in the field. There are so many variables that cannot be accounted for when you are deliberately trying to break rope in a controlled setting. The materials we have access to are very strong and “testing” numbers are often way more than a thoughtful arborist with good judgement would ever generate while rigging. Not to mention the weakest link is often the tree!
It has always been a challenge in writting artilces trying to find a practical balance between theory and practice, data and in-field experience. I appreciate the comments/ feedback and mostly the time you chose to spend with me and my thoughts vicariously through the medium of reading.
Tony
When I tie a cow hitch as a termination of a crane sling,, I’ve been thinking about my last half hitch finish to be around the stem, and in the opposite direction of pull, not the standing part of line.
One would rarely have enough sling length to accomplish this when tying off a block to a larger diameter trunk section. I do think the effect of the tail doing something “useful” beyond the bar would make a difference. Testing would be required, but I often have a marl or two above the cow hitch anyway, so it probably makes no difference.
Subjective. Personal taste so long as it is truly safe and effective.
